Thread: ? about a motor swap
Results 1 to 6 of 6
  1. #1 ? about a motor swap
    SE Level Member krimsonwolf's Avatar
    Jul 2010
    knoxville tn
    the car i bought is a GT but the guy swaped for a GTP motor i was wondering if i got a chip for a GTP if it would work fine. the only Diff is the SC right?
  2. #2 Re: ? about a motor swap
    Donating Users ninnyGTP's Avatar
    Nov 2008
    Moreno Valley, California
    Well considering he's got a L67 motor in it, chances are it's already got a tuned PCM. Quick way to tell is ZZP labels theirs, intense usually throws a sticker on it as well (not sure about the other venders)... or, all the venders have their fans stay on for 10 seconds with the car off after it has reached I think 180* coolant temp
    98 Grand Prix GTP L32, GenV, n*, 3.2", 1.9 rr's, 3.29 gears. All that jazz SOLD
    99 Mustang GT Steeda UDPs, 3.73s, Pypes O/R xpipe, Accufab plenum, Steeda CAI, B&M ripper, MHS s2 cams, 10.5:1 compression (290whp/310wtq) SOLD
    01 SVT Cobra #3654, B&M Ripper, K&N FIPK2, MAC O/R xpipe
  3. #3 Re: ? about a motor swap
    what 'chip' are you referring to? if he did an l67 swap, i would hope that he had a good tune on it as well.
  4. #4 Re: ? about a motor swap
    Nov 2008
    LMFAO!! Thanks Bio. When you go from L32 to L67 in enough threads you're mind just get's confused haha
  5. #5 Re: ? about a motor swap
    Jul 2010
    knoxville tn
    im not really sure im over in afganastain right now guys im just doing a lil before hand research for when i get home i have a system and order to buy parts for my upgrades. ive read through the bibble and have a pretty good warm and fuzzy about what i need but i dont have the abbility to call the old owner from here to get a the info on whats been done to it so far. i guess it was a nooby ? to ask i was just makin sure that i wouldnt be limted to a N/A chip because of (i dont know reallly) lets say it wouldnt connect or something.
    "Quick way to tell is ZZP labels theirs, intense usually throws a sticker on it as well "
    thanks ninny for this lil but of info it prolly dosnt seem like much but at least it reasures me
    anyway you guys know if there's anyother diffrance between a stock L32 and a L67?
    does the car come stock with sloted rotors?
    thanks everyone any thank you bio for you input and this and so many other threads.
  6. #6 Re: ? about a motor swap
    Nov 2008
    L67 is the Series II supercharged motor. L32 is the Series III supercharged motor. You can run the stock L67 tune on an L32.
    As for the L36 (series II N/A) and L26 (Series III N/A) They have a much more agressive tune just due to them being n/a. That and the gearing on the trans is quite different from the GTP and GT/SE (2.92 for GTP's and 3.29 for GT's/SE's) Which is why I mentioned that if indeed he did the L67 motor swap he's more than likely (or atleast SHOULD be) running an aftermarket tune.
  1. Motor swap
    By tracker1925 in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-26-2010, 03:44 PM
  2. motor swap
    By ericevenski in forum 3.4L V6 (LQ1) DOHC
    Last Post: 02-22-2010, 01:40 PM
  3. NEED HELP: motor swap
    By fst in forum Northeast
    Last Post: 08-27-2009, 08:50 AM
  4. Motor swap
    By redgp89 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-28-2009, 01:00 AM
  5. Motor Swap
    By Dohner in forum General Tech Discussion
    Last Post: 08-07-2008, 10:59 AM
