Hey if i install a tuned PCM in the next few days with already having headers and CAI (No pulley yet), will i feel any difference in power or anything else? Thanks![]()
And you'll run pig rich since it commanding more fuel to compensate for the higher boost rate.
PE = Power Enrichment. It's what the PCM locks into for the commanded AFR when you pass a certain throttle percentage.
What Blue is really trying to say here though, is if the fuel trims are way off, then your PE will be off. Being that this all goes off of your LTFT and STFT average, if the car is running rich to begin with, then your Power Enrichment will be rich, and the same goes to if it's lean.
Either way, out of both, you obviously want it to be rich, but it won't be as bad as most people think pulley wise.
lol i meant for americanrice eater as he is only 75 minutes away...also the pcm will command fuel based on the maf reading and the settings for fuel ratio in the computer. u can have no pulley or a 2.6 pulley and the computer will still run off the maf to determine gas based on the calculation for desired afr. your injectors wont hold this of course but im saying this to make a point. now if the maf reading is wrong or tuned wrong of course the computers calculation will be wrong but thats it. ive gone from a 3.4 pulley to a 3.25 and now im at a 3.1 and ive yet to need to retune the pcm for afr or maf at any boost rate and i have consistently run within +/- 3 for my fuel trims and afr
