Thread: 99 GT Coupe shuts off while driving....HELP!
Results 1 to 5 of 5
  1. #1 99 GT Coupe shuts off while driving....HELP!
    SE Level Member grandprix17's Avatar
    Cleveland, OH
    Hey guys,
    My GT coupe for some reason keeps wanting to shut off when I'm driving and it is not good. It has happened to me numerous times. I have taken it to Pontiac and since the car doesn't have a check engine light on, they can't find anything and says it's fine even after testing and keeping it for a couple of days. What should I do? I'm thinking of selling it cause I don't like driving it knowing that ant any moment it will shut off
  2. #2 Re: 99 GT Coupe shuts off while driving....HELP!
    Crank Position Sensor can make it do that. I would try replaceing it, also does the rpm gauge ever drop to zero while driving, if it does the CPS needs to be replaced.
  3. #3 Re: 99 GT Coupe shuts off while driving....HELP!
    SE Level Member NashGT02's Avatar
    Davenport, IA
    its ur computer or ignition switch or crank senser like FFDP said. my moms regal did the same thing turned out to be ignition switch but it got so bad we couldnt hardly drive it or start it luckily we only lived 2 blocks away from the dealership so we just drove it over to them and had them look at it.
  4. #4 Re: 99 GT Coupe shuts off while driving....HELP!
    Nov 2009
    Grand haven
    My car did the same thing and it was my MAF that was going bad.
  5. #5 Re: 99 GT Coupe shuts off while driving....HELP!
    New orleans
    Crank sensor cam sensor or Maf...
    I replaced all 3...
    had to unplug the maf for it to stop
  1. Car shuts off after a few seconds of running
    By Kissner in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-17-2010, 10:51 PM
  2. Car Shuts Off When Engine Warms Up
    By 1999GTP1999 in forum General Tech Discussion
    Last Post: 01-23-2010, 04:22 PM
  3. just shuts off
    By QwikGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-04-2009, 12:16 AM
  4. Engine shuts down
    By jvee44 in forum General Tech Discussion
    Last Post: 06-23-2009, 01:38 PM
  5. Car starts then as its about to Idle, car shuts off
    By fasterthenu2000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-06-2009, 05:51 PM
