Thread: sputtering problem
Results 1 to 5 of 5
  1. #1 sputtering problem
    SE Level Member Risinnfallen's Avatar
    Lombard, IL
    Lately my car has been kinda up and down upon start up ( but doesnt die).At first i didnt think anything of it but now when i get on it a lil, it sputters out. My pulleys and belts are fine. I checked my trans fluid lvl and noticed it being way high. Would the high lvl be due to the new PCM? and if so could this be a problem or possibly the problem in my case? thkns
  2. #2 Re: sputtering problem
    Saraland Alabama
    pcm won't overfill a trans, but that shouldn't cause an poor running engine, a vacuum leak, or bad fuel filter will cause that (as well as a few other things)
  3. #3 Re: sputtering problem
    Barksdale AFB, LA
    I used to have an issue where if on a hill, I gave it a little gas and let off it would almost die. Turns out my IAC was dirty. Just a thought.
    2009 Subaru Impreza WRX STI
  4. #4 Re: sputtering problem
    Lombard, IL
    actually, my check engine light went on yesterday...after getting on it a bit, anyways, i scanned it and it was just a misfire in cylinder one. I changed the plug and wire just to be safe but still it does it. Im thinkin i need to look towards the coil now...
  5. #5 Re: sputtering problem
    minneapolis, mn
    i recently had a problem with that happening... i check the MAF sensor and it read fine but thats the code that kept popping up. what was happening is the wires connecting to the MAF were rotted and once i replace the wires and connector it ran superb. I got it done a t a dealership for .5 hours and a $20 connector. that would be my suggestion. fiddle with the wires and see if you get any chugging thats a key indicator
  1. HUD problem
    By the1euge in forum General Tech Discussion
    Last Post: 08-31-2009, 12:23 PM
  2. HUD problem
    By 99GPGT in forum General Tech Discussion
    Last Post: 05-31-2008, 03:21 AM
  3. Help Problem Please Look!
    By Incomudrox in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-20-2008, 12:22 AM
  4. 97 gp one problem after another
    By vermsta in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-17-2008, 08:44 PM
  5. Another HUD problem
    By SlowPurpleGTP in forum General Tech Discussion
    Last Post: 03-10-2008, 05:51 PM
