Thread: L32 in a 97 gtp
Results 1 to 5 of 5
  1. #1 Re: L32 in a 97 gtp
    GTP Level Member
    Pittsburgh
    ick, your gonna have problems interfacing the L32 PCM with your 97.
    first off, the PCM is 100000% different
    second the L32 PCM cant communicate to your car
    third, your PCM cant controll that transmission
    I can go on if you desire.....
    your best option is the use your 97 PCM install the L32 and rebuild the Current Trans
    2003 SSEi,
  2. #2 Re: L32 in a 97 gtp
    Jan 1970
    Maquoketa, Iowa
    I would use the L32 + 4t65E HD (L32 trans) in your car if you have a tuner. You will need a 2003 PCM with service number 12209624. Also will need a 98-03 harness since yours is a 97. You will need to flash a 03 gtp file on that pcm if it doesn't come from a 03 gtp. You also need to change to 3.29 gear in the pcm file. This *should* work.
    The 97's are a crap year as far as wiring harness, pcm and vac. If you can get the L32 engine/trans and everything at a reasonable price, I don't see why not.
gtp, l32
