Thread: .
Results 1 to 9 of 9
  1. #1
    SE Level Member Leon's Avatar
    Apr 2009
    US
  2. #2 Re: Does not crank
    HUDSON
    Start with the simplist thing first, check your battery cables and engine grounds. If those are all good, the next thing to do is to remover the starter and have it checked out. how many miles are on it? Worn brushes in the starter will make the starter not spin as fast as a new one, thats the most common problem when a starter begins to loose power.
  3. #3 Re: Does not crank
    Apr 2009
    US
  4. #4 Re: Does not crank
    GTX Level Member Rather B Blown's Avatar
    Dec 2008
    London, Ontario
    how do you know the battery is good?
    Quote Originally Posted by Reptile
    It sounds like you accidentally stuffed a midget in the downpipe, and he's hammering out an SOS to get out.
  5. #5 Re: Does not crank
    Apr 2009
    stockton ca
    If theres no crank/ Like others have said start simple i would clean bat terminals check all conections if you have a volt/multi meter do basic checks make sure power is getting where it needs to go
    K.I.S.S it will always lead you down the path of least resistence
  6. #6 Re: Does not crank
    Apr 2009
    US
  7. #7 Re: Does not crank
    Apr 2009
    US
  8. #8 Re: Does not crank
    GTX Level Member kjohnson's Avatar
    Nov 2008
    Harlan, IA and University of Northern Iowa
    check power getting to the starter make sure your getting your 12vts if not I think there may be a relay for the starter if the fuse isnt blown. try replacing that. its cheep
    silver 2003 Grand Prix GT List is on it's way to be updated
  9. #9 Re: Does not crank
    Stafford, Virginia
    Mine is doing the same thing. I had a new battery put in it and no effect. Seems like engine is very "tight", but it runs smoothly and idles fine. Did you ever figure yours out?
  1. Crank, but no start
    By JoshMcMadMac in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-24-2010, 11:28 PM
  2. crank no spark
    By schmuve in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-06-2010, 12:21 PM
  3. Sluggish crank
    By Fubisin in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-14-2009, 02:21 PM
  4. HELP! Cranks then Don't Crank
    By Bigboy49251 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-09-2009, 03:25 PM
