Thread: Negative Pressure Supercharging! i guess we have it all wrong acording to them...
Results 1 to 4 of 4
  1. #1 Negative Pressure Supercharging! i guess we have it all wrong acording to them...
    Florida
    http://www.impulsengine.com/how/what_is_nps.shtml
    they claim to turn a 4cycle engine into a 6!
  2. #2 Re: Negative Pressure Supercharging! i guess we have it all wrong acording to them...
    Hmm interesting. If this thing actually works and has been working for the past 5 years like they say why has no one heard of it? Why do they not have any videos showing this system in action? Why no dyno sheets? I smell some pretty thick BS. They claim their kit costs less than a standard supercharger or turbo kit yet its priced at $8,000, and they say their crate engine is 1/2 the price of a normal supercharged crate engine there crate engines cost $14,000. Um ok I am pretty sure I could supercharge or turbo charge any other engine for less than $8,000 and I am sure you could order a supercharged crate engine for less than $14,000.
  3. #3 Re: Negative Pressure Supercharging! i guess we have it all wrong acording to them...
    I live here. TLSheff's Avatar
    "Vacuum Supercharging or "heaps more suction" may be easier to understand by the average laymen, but technically the process is Negative Pressure Supercharging. This is because the pressure in the cylinder must be reduced FIRST in order to create a vacuum or suction. Therefore, the more the pressure is reduced in the cylinder, the higher the vacuum or suction, the more air is pulled into the cylinder."
    So the vacuum in the cylinder after detonation isn't enough, we need MORE vacuum, so were going to play with the cam shaft, valve train, and MAKE it suck in more air... and this is negative supercharging....
  4. #4 Re: Negative Pressure Supercharging! i guess we have it all wrong acording to them...
    Pennsylvania
    Definite Snake Oil. Such things do not simply elude well-paid engineers with vast resources.
  1. supercharging
    By gprix01 in forum General Tech Discussion
    Last Post: 10-05-2011, 10:24 PM
  2. Can't Figure Out Positive or Negative Wires
    By milo033 in forum Audio, Security & Visual Electronics
    Last Post: 01-03-2011, 10:19 PM
  3. Negative Battery Bolt size
    By garreTT in forum General Tech Discussion
    Last Post: 09-04-2010, 08:41 PM
  4. wich speaker wires are positive and negative
    By PNIGZ in forum Audio, Security & Visual Electronics
    Last Post: 02-14-2010, 08:02 PM
  5. Supercharging an L36?
    By Todd0990 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-24-2009, 09:30 PM
