Thread: 97 GTP Tuner questions
Results 1 to 2 of 2
  1. #1 97 GTP Tuner questions
    SE Level Member kikkinasphalt's Avatar
    Jun 2010
    Missouri
    those of you who are tuner guru's have a look, tell me what im looking at here?
    i just bought this car and i know nothing about it lol
    YouTube - GTP Tuner
    97 GTP ; Modified
  2. #2 Re: 97 GTP Tuner questions
    Jan 1970
    Maquoketa, Iowa
    It's a ZZP ICCU as it says on startup. You can adjust timing, fuel and a few other things. The Maf Hz is the frequency you are hitting on the maf. The higher the frequency, the more air is coming through the engine. You can also adjust your timing throughout your rpm range. Right now it is set to pull some timing, which is probably good until you can monitor knock.
  1. pcm tuning questions with hp tuner
    By e6600 in forum General Tech Discussion
    Last Post: 03-29-2010, 07:36 PM
  2. Alky Questions & Other Related Questions.
    By rynoman03 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-22-2010, 07:57 AM
  3. Tuner for L26
    By Vioarr in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-04-2010, 01:19 AM
  4. I think I need a tuner....
    By 01gtspecial in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-28-2009, 06:18 PM
  5. just got my hp tuner...questions!!!!
    By TDCRacing in forum PCM Tuning
    Last Post: 02-27-2008, 08:40 AM
