Thread: someone please tell me what could be wrong...
Results 1 to 14 of 14
  1. #1 someone please tell me what could be wrong...
    GT Level Member backinblackgtp's Avatar
    Nov 2009
    centereach, NY
    since ive owned my 2001 gtp its shaked at speeds from 45 plus. Ive now had 2 different sets of rims, which i 4 put new tires on both, got an alignment twice in 8 months, balanced the wheels, had a front sway bar replaced along with 2 front wheel bearings, and now it STILL shakes. BUT, it only shakes around 50-65 mph when im doing 75-80 on the highway it doesnt shake what so ever doesnt steer to one side, nothing. i have gone to 2 different mechanics, and than had my wheels and everything done at a tire shop and they claim nothing is wrong with the suspension. I'm at a loss, so any help would be appreciated
  2. #2 Re: someone please tell me what could be wrong...
    GT Level Member kuntzie's Avatar
    Feb 2010
    Kitchener, Ontario, Canada
    axles are possible.
    02 Grand Prix GT Intercooled turbo 5-speed 718whp 618wtq @ 21psi 7575 billet, spool valve, custom manifolds, 4" downpipe, 16way adjustable coilovers, 18x9.5 with 275's all around, gxp interior, gxp brakes
    tilton triple disc, custom aluminum flywheel, tilton slave and master, an awful lot more
  3. #3 Re: someone please tell me what could be wrong...
    Apr 2009
    stockton ca
    axles would show up on accell but anythings possible
  4. #4 Re: someone please tell me what could be wrong...
    Feb 2010
    if a axle is completely gone ie siezed the the vibes may show up at a certian speed, i have seen it happen before. but it usually changes in speed like it happens at ransom speeds
  5. #5 Re: someone please tell me what could be wrong...
    Nov 2009
    centereach, NY
    so this couldnt be the trans going, because lately its been shifting into 4th gear really low, about 46 mph, which leaves my RPMS around 1400
  6. #6 Re: someone please tell me what could be wrong...
    SE Level Member shawnheck03gtp's Avatar
    Billings, MT
    mine has shifted that way since i bought it and had two different trannys in it. and i had the same problem and it was the axles
  7. #7 Re: someone please tell me what could be wrong...
    Nov 2009
    Grand haven
    Hub rings?
  8. #8 Re: someone please tell me what could be wrong...
    Donating Users Viperkill97's Avatar
    Arizona
    What kind of shaking are you talking about a vibration or side to side?
    Life goes by so fast, so why drive slow.
  9. #9 Re: someone please tell me what could be wrong...
    Nov 2009
    centereach, NY
    its mostly the steering wheel it shakes side to side and when i have someone else in the car, they cant even feel it in the passenger seat.
  10. #10 Re: someone please tell me what could be wrong...
    Outer Space
    its your axles I bet. When was the last time they were replaced? Also, do you see grease on the LCA's ?
    Mine would do it from 20-45 ... i would be bouncing ..literally.
    02 GTP 13.6 @ 100mph - SOLD
  11. #11 Re: someone please tell me what could be wrong...
    Nov 2009
    centereach, NY
    how can i be my axels, wouldnt my car not move if the axels broke? and ive gotton the front Tie rods replaces along with one bearing and the front sway bar too. and i brough it to mavis tire and they said nothings wrong?
  12. #12 Re: someone please tell me what could be wrong...
    Akron Ohio
    They dont have to be broke to be bad.
  13. #13 Re: someone please tell me what could be wrong...
    Nov 2009
    centereach, NY
    think it could be that the wheels arent balanced?
  14. #14 Re: someone please tell me what could be wrong...
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Axles are bent is where id look. had the same issue on a Honda civic.
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  1. WTF is wrong now? 99 GTP
    By LSXHP in forum Audio, Security & Visual Electronics
    Last Post: 03-12-2010, 12:42 PM
  2. What am I doing wrong??
    By silverstreak in forum Off Topic Discussion
    Last Post: 09-11-2009, 08:59 AM
  3. need some help, something is seriously wrong
    By red60degreeGP in forum General Tech Discussion
    Last Post: 07-08-2009, 09:16 AM
  4. Something's Very Wrong
    By BwolfGT in forum Track Sessions and Kills
    Last Post: 04-24-2009, 10:04 PM
  5. WTF am i doing wrong
    By 04 GTP COMP G in forum Forum Bugs/Suggestions
    Last Post: 12-29-2008, 05:43 PM
