Thread: Supercharger Not Creating boost.
Results 1 to 5 of 5
Nicorette02 Supercharger Not Creating... 05-01-2008, 04:41 PM
Smokedgtp Re: Supercharger Not Creating... 05-01-2008, 08:00 PM
Meemperor Re: Supercharger Not Creating... 05-02-2008, 01:32 AM
blowfishRus6 Re: Supercharger Not Creating... 05-06-2008, 05:14 PM
Guest Re: Supercharger Not Creating... 05-12-2008, 04:28 PM
  1. #1 Supercharger Not Creating boost.
    May 2008
    Could Someone please give me an idea why my Supercharger is not creating more then 1lb of boost? i noticed that the car was a little slower then normal and the boost gauge wasnt working. So i hooked up a mechanical boost gauge and it would barely go above zero. PLEASE HELP ME. Thanks Nick
  2. #2 Re: Supercharger Not Creating boost.
    SE Level Member Smokedgtp's Avatar
    It has to be making boost. Check the BBV
    CT 61mm turbo, 3" DP, DHP tuners, SD spoiler, SSC springs, 17" mustang wheels, and much more
  3. #3 Re: Supercharger Not Creating boost.
    GT Level Member Meemperor's Avatar
    Toronto, ON, Canada
    Check all your vac lines and the connector the connector that goes to the BBV. Most likely your issue.
    Lumpy Gen 3
  4. #4 Re: Supercharger Not Creating boost.
    Donating Users blowfishRus6's Avatar
    g.a.
    what about the boost syloniod not being in the right possition and not closeing all the way.
  5. #5 Re: Supercharger Not Creating boost.
    TDCRacing
    Guest
    you didnt do a top swap and use a different pcm did you? as already stated check your bbv
  1. what limits boost
    By deangtp in forum PCM Tuning
    Last Post: 04-08-2008, 03:53 PM
  2. What is Vacuum on a boost gauge ??
    Last Post: 04-07-2008, 12:54 PM
  3. Stock L36 + Boost =
    By Sinister Performance in forum General Tech Discussion
    Last Post: 02-22-2008, 11:28 PM
  4. any gains in porting the boost bypass passage?
    By fst in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-18-2008, 10:59 AM
  5. Most Accurate Boost Guage?
    By RNUOVR in forum Off Topic Discussion
    Last Post: 01-07-2008, 03:38 PM
