The first thing I would do. Clean the maf sensor with electonic parts cleaner. PLEASE USE ONLY THIS! any thing else will leave a residue, and do not touch the wires on the inside of the maf sensor.
GM Codes should be either P0361 or P1361, likely you get the same results either way. But check them out. As far as asking for help. I'm a fan of the OP listing out the name of the code. That way as a quick hit helper it's easy to remember the common fixes based on the code.
