Thread: Minor Modding/Tuning Up
Results 1 to 20 of 33
  1. #1 Re: Minor Modding/Tuning Up
    Quote Originally Posted by motorking View Post
    Brandon,
    I work as the technical manager at Autolite. As long as you have not done anything to raise the boost or compression in your car, you should not use a colder spark plug. there is simply no benefit to doing so at all. What may happen is a fouled spark plug, a failed cold start or partially fouled plugs. The reason you would need to go to a colder plug can be found by watching the videos posted at www.autolitechallenge.com/pro. The 5th video in the series explains what spark plug heat range is all about, when and if you would need to change heat ranges. You can also get a Autolite branded Carhart jacket for watching all 6 video's. There is one video about the DIS ignition on your car as well.
    You should also stay away from using a copper core spark plug unless you really enjoy changing spark plugs. Your DIS ignition fires one half the spark plugs in the opposite direction, meaning the spark actually jumps from the side wire to the center wire. using any copper plug in a DIS ignition vehicle is a mistake that will cause rapid degradation in the sidewire and misfires in as little as 16k miles. Use the Autolite XP606 Iridium fine wire plug. Yes, they cost 7 bucks a piece. They are worth it. They take less ignition voltage to fire and have a 25% larger flame kernal than the stock plug. The also have a platinum button on the side wire to prevent gap erosion. They have a 100k life span as well. If I can answer any other questions for you, please feel free to contact me at Jay.Buckley@Honeywell.com
    great, super informative post.
  2. #2 Re: Minor Modding/Tuning Up
    Bio, you should some how like STICKY it or put that somewhere where other people and can see it and that way they can all know about it. I dont how you can do it, but i think it worth a shot.
  3. #3 Re: Minor Modding/Tuning Up
    Pennsylvania
    Funny, I was just in a conversation with a coworker on the merits of copper, iridium, and platinum plugs. It's good to see information from someone in a position to know.
    Jay Buckley is the Technical Manager (which means he teaches mechanics around the world) for Honeywell Consumer Products (Autolite, Fram, Prestone), is an ASE and Michigan Master Technician (30 yrs), and (part?) owner of Motorking Automotive (22yrs?) in Shelby Twp, Michigan. I like the hell out of where this information is coming from.
  1. minor scrubbing
    By BoostJunki3 in forum Tires & Wheels
    Last Post: 06-06-2010, 11:14 PM
  2. Before and After with Borla *minor update*
    By rocafella2032 in forum Visual/Body Modifications
    Last Post: 11-30-2009, 09:45 PM
  3. Minor electrical issues. any help?
    By NMillis in forum Audio, Security & Visual Electronics
    Last Post: 04-21-2009, 10:37 AM
