Hello, i just picked up a 99 gtp as a DD for the time being and enjoy it quite alot. It has a few issues which i would like to take care of. The main one that bothers me is the readout on the center of the dash that displays the boost, MPG..etc does not work. I was not sure what this readout was called, so i had a hard time finding any info on what the issue could be. My friend used to have one so i am familiar on what the car should act like. Im guessing it could be a fuse but from my quick check on the fuse panel found none that were blown. Also the windows do not work(its a 2 Door) im suspecting a window switch or motor issue. other than that its a good little car i picked up for cheap and is actually a fun little car to drive(hard to stay out of boost)
any help would be greatly appreciated, thanks
