Thread: e85 in 97-03 gtp?
Results 1 to 7 of 7
SwatRaptor e85 in 97-03 gtp? 05-06-2011, 03:55 PM
dsmuts Re: e85 in 97-03 gtp? 05-06-2011, 03:57 PM
Bio248 Re: e85 in 97-03 gtp? 05-06-2011, 04:08 PM
RamonGTX Re: e85 in 97-03 gtp? 05-06-2011, 04:58 PM
Bio248 Re: e85 in 97-03 gtp? 05-06-2011, 05:11 PM
RamonGTX Re: e85 in 97-03 gtp? 05-06-2011, 05:25 PM
TheOtherNick Re: e85 in 97-03 gtp? 05-06-2011, 06:13 PM
  1. #1 e85 in 97-03 gtp?
    Iowa
    has anyone tried running straight e85, or even a mixture of regular fuel with e85?
  2. #2 Re: e85 in 97-03 gtp?
    You need a tune and bigger injectors I'm pretty sure but don't quote me on any of that.
  3. #3 Re: e85 in 97-03 gtp?
    bigger injectors and a tune. replace the fuel filter a couple times. done.
    since you either didnt search, or tried to search 'e85' which returns nothing since it is 3 characters, search 'ethanol'.
  4. #4 Re: e85 in 97-03 gtp?
    GT Level Member RamonGTX's Avatar
    menasha wisconsin
    ive seen the 93 octane at the Renew stations and it says its 20 percent ethanol and should only be ran on flex fuel cars...would it be a problem on our cars since we run 93 anyways? its cheaper too
    Polished Gen V, 3.1 mps, intercooled, S1X cam, northstar tb, and Tim King built trans with 3.29s and all the good stuff
  5. #5 Re: e85 in 97-03 gtp?
    you might run lean with it since youre tuned for gas, but you might also be okay because you can run leaner with ethanol.
    either way, only way to know is to fill it up and scan.
  6. #6 Re: e85 in 97-03 gtp?
    menasha wisconsin
    I might just do that! i just dont wanna break anything hahah
  7. #7 Re: e85 in 97-03 gtp?
    Charles City, IA
    Where are ya in iowa I run E-85.
    SMGPFC Two Nipple General
