Thread: yet another stalling issue
Results 1 to 2 of 2
  1. #1 yet another stalling issue
    lynn, ma
    ok- 2000 gtp l67. stalls out either as soon as it starts or shortly thereafter. when it does run it sounds rough. i can hear the fuel pump prime before it starts, and i can hear it running after the car stalls. this started thursday, it stalled, then ran rough for a few minutes then straightened itself out, then i drove it for a few hours with no trouble, then just as i was gettng home it started to die again, luckily it was late, and i floored it and limped it home.
    this is what i've done so far:
    1. replaced fuel pump speed relay
    2. used old relay (that i didn't think was the issue anyhow and bent the pin to bypass the resistor
    3. verified the iac was moving and cleaned it up some
    4. unplugged the maf- it ran for a bit without stalling, but it was rough and surging up and down, bad enough i thought it was a good idea to shut it off.
    5. checked all vacuum lines- and fixed one at the map sensor that looked really bad. also didn't smell any fuel in fuel pressure regulator
    6.gor a fuel pressure tester from autozone- fuel pressure at prime was 55, which looked good to me, and it seemed to hold a bit, but the connection at the schrader valve was a piece of crap and started leaking and i wasn't going to try to run it like that, nor do i think it would have worked well anyhow.
    the only other clue i can give is that the fuel pump sounds a lot louder than i've noticed, but that may only be because i'm really listenng for it.
    any help diagnosing this would be greatly appreciated. if i take the bus to work i still have to walk a mile. and thats after an hour long bus ride.
  2. #2 Re: yet another stalling issue
    GTX Level Member cerick08GP's Avatar
    Well, IMHO it is the cat. If the car has over a 120k just do it.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  1. Stalling Hot Issue Need Help...
    By BPGPSE in forum General Tech Discussion
    Last Post: 06-13-2010, 09:26 PM
  2. New Here and Have Stalling Issue
    By BPGPSE in forum Introductions/Noob Questions
    Last Post: 06-12-2010, 07:14 PM
  3. Intermittent Starting Stalling Issue
    By daniel981 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-04-2009, 07:20 AM
  4. working on an stalling issue
    By alexo1us in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-18-2009, 05:56 PM
  5. MAF / stalling issue
    By the1euge in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-14-2008, 11:16 AM
