hello all. i had both of these replaced less then a year ago by a very good shop, and now my drivers side one is leaking grease again. i have found the "slit" in the boot so im confident its the cv shaft.
as far as removing goes, i think ive got most of it, disconnect ball joint, tie rod end, sway bar link. remove the nut from the end of the shaft and pound on it to loosen it from the bearing......
i only have 2 questions tho
what is the exact size of that nut?? ive heard 32mm, ive heard 33mm, and ive read 34mm. with sockets being $10-20 a piece, i would only like to buy one and be done... my second question is, once i get everything moved and am ready to remove the shaft, do i just give it a hell of a good tug, or is there something that needs to be unsecured first?? i understand i will want a drain pan underneath when i do this...
also, is there anything else i should know before tackling this?
