Thread: DRL module going bad?
Results 1 to 3 of 3
  1. #1 DRL module going bad?
    Jan 2009
    MN
    So while driving around with my daytime running lights on I notice my headlights flickering on and off, along with a loud clicking from the dash. Sounds like it is coming from the left of the steering wheel and sounds like a relay clicking on and off. I assume the DRL module is failing, has anyone else had this happen? Or could this be a wiring issue somewhere? Are these parts known to fail? Thanks...
  2. #2 Re: DRL module going bad?
    Apr 2009
    Wausau, Wisconsin
    check the fuse, thats what it does when the fuse pops.
  3. #3 Re: DRL module going bad?
    SE Level Member Silent Drifter's Avatar
    Colby, Wisconsin
    When I pulled my fuse for the DRL, the module in my dash started making that clicking noise. So like Stunt0Rider, it could be your fuse. If that doesn't work, I guess you could replace the module, or unplug the wire from the module and have no DRL
    2003 Pontiac Grand Prix GT - Yeah, it's stock.
  1. Exhaust module?
    By silverbullet10 in forum General Tech Discussion
    Last Post: 06-29-2010, 07:52 AM
  2. ABS module interchangability
    By alexmerchant in forum Brakes/Suspension/Chassis
    Last Post: 03-29-2010, 08:55 PM
  3. Tac Module
    By Skeeve in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-25-2010, 11:30 PM
  4. abs module
    By tlaloczint in forum Brakes/Suspension/Chassis
    Last Post: 02-20-2010, 11:43 AM
  5. Module?
    By GTPluv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-22-2009, 05:16 PM
