Thread: What tools for front brakes
Results 1 to 14 of 14
  1. #1 What tools for front brakes
    SE Level Member KenH83's Avatar
    I've got a 2005 Grand Prix GT and the dealership wants an absurd amount of money to do front brake pads and rotors.. What do I need besides a set of sockets and a C-Clamp (to push the caliper piston back) to change the front brake pads AND rotors .. do i need any special large hex or allen wrench to remove the caliper mount bracket to be able to remove the rotor ?
    Ken H.
    Grand Rapids, MI
    2005 Grand Prix GT - STOCK.
  2. #2 Re: What tools for front brakes
    GTX Level Member cerick08GP's Avatar
    You don’t need much, I’d say you probably have every thing you need tool wise.
    #1 Make sure your sockets are metric. IIRC the caliper bolts are 15mm.
    #2 I highly recommend having a breaker bar available.
    #3 You have the C-clamp. Nice Ensure you take off your brake cylinder fill cap.
    #4 High temp grease for the caliper slider bolt thingy.
    #5 No allen or hex wrenches required.
    Good luck, but you won’t need it. Brakes are easy.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  3. #3 Re: What tools for front brakes
    Thanks cerick08GP .. I know that brakes are easy, i've done them plenty of times in the past on many many vehicles.. so doing them isn't the problem .. just having the tools to do them is the problem. Its my only vehicles so once i get it off the ground and start taking things a part .. if i dont have something that means put everything back together in order to go get a stupid hex or allen wrench
    You say to take off the fill cap? I've never done this in the past, but I can only assume that its a good idea. You're talking about where the brake fluid reservoir is.. correct?
    Ken H.
    Grand Rapids, MI
  4. #4 Re: What tools for front brakes
    Yup that cap, you may or may not HAVE to remove it. If your brakes have been worn down and someone topped off the brake reservoir when you push the cylinders back (with the C clamp) you could run out of room and blow something.
    2008GP
    2002GP||sold
  5. #5 Re: What tools for front brakes
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    if u have to ask then i wouldnt do it
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  6. #6 Re: What tools for front brakes
    Charles City, IA
    Quote Originally Posted by nascartech View Post
    so you know every socket that is needed for any job on any car?
    The twist in pistons are only in the back you can tell its them by the + in the piston and it is not a cup.
    SMGPFC Two Nipple General
  7. #7 Re: What tools for front brakes
    SE Level Member RideMr2's Avatar
    Memphis
    I changed the rotors/pads on my 07 recently, I went with slotted/drilled ones.
    There were little tiny clip on rings around the lugs, you may or may not have them, depends if the rotors have been changed before. They came off with a pair of needle nose pliers.
    When you take off the brake fluid cap, get a paper towel(clean, new) and use it to soak up some of the fluid.
    And x 2 on the breaker bar. I tried it at first with a ratchet, I broke 2 of them, and busted several cheap made in china sockets with a craftsman breaker bar borrowed from a neighbor.
    The twist calipers are only on the rear.
    Mine was rough, because the rotors had never been off the car.
  8. #8 Re: What tools for front brakes
    not every job but if u own the car u should know thats all im saying
    sold 97 GTP stock
  9. #9 Re: What tools for front brakes
    Outer Space
    remember some 04+ have those twist in calipers. I had a friend with an 07 that tried the c clamp method....and caused more headace than anything
    02 GTP 13.6 @ 100mph - SOLD
  10. #10 Re: What tools for front brakes
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    this tool is easier, and safer (for your car) then a C clamp. for as often as a do-it-yourselfer like myself does brakes, its well worth the $10
    Lisle 24400 - Pad Spreader | O'Reilly Auto Parts
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  11. #11 Re: What tools for front brakes
    MO
    When I had to take mine off, the caliper bolts were loc-tite'd in place. needed a long breaker bar, and for 2 of the bolts i had to hold a blow-torch to them to loosen it up. If the brakes have been done on your car before, you shouldn't have this issue. Just FYI
    <brandonl2000> LMAO D!!
  12. #12 Re: What tools for front brakes
    Charles City, IA
    Quote Originally Posted by ZR1Vette09 View Post
    you should use some blue locktite on the caliper bracket bolts.
  13. #13 Re: What tools for front brakes
    MO
    I was the first one to service the brakes and it came with the red stuff
  1. 07 GXP Front Brakes
    By Fireof59 in forum Brakes/Suspension/Chassis
    Last Post: 05-24-2010, 05:14 PM
  2. Front brakes
    By MikeB91 in forum Brakes/Suspension/Chassis
    Last Post: 05-20-2010, 07:48 PM
  3. ls1 brakes up front
    By stanggreg90 in forum Brakes/Suspension/Chassis
    Last Post: 04-12-2010, 12:32 PM
  4. Installing front brakes
    By GPSims39 in forum Brakes/Suspension/Chassis
    Last Post: 06-29-2009, 09:48 AM
  5. F-Body front Brakes
    By TMC in forum Brakes/Suspension/Chassis
    Last Post: 01-19-2009, 11:49 PM
