Thread: What tools for front brakes
Results 1 to 14 of 14
  1. #1 Re: What tools for front brakes
    Charles City, IA
    Quote Originally Posted by nascartech View Post
    if u have to ask then i wouldnt do it
    so you know every socket that is needed for any job on any car?
    The twist in pistons are only in the back you can tell its them by the + in the piston and it is not a cup.
    SMGPFC Two Nipple General
  2. #2 Re: What tools for front brakes
    SE Level Member RideMr2's Avatar
    Memphis
    I changed the rotors/pads on my 07 recently, I went with slotted/drilled ones.
    There were little tiny clip on rings around the lugs, you may or may not have them, depends if the rotors have been changed before. They came off with a pair of needle nose pliers.
    When you take off the brake fluid cap, get a paper towel(clean, new) and use it to soak up some of the fluid.
    And x 2 on the breaker bar. I tried it at first with a ratchet, I broke 2 of them, and busted several cheap made in china sockets with a craftsman breaker bar borrowed from a neighbor.
    The twist calipers are only on the rear.
    Mine was rough, because the rotors had never been off the car.
  3. #3 Re: What tools for front brakes
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    not every job but if u own the car u should know thats all im saying
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  4. #4 Re: What tools for front brakes
    GTX Level Member noreasonwhyy's Avatar
    Michigan
    ever considered the fact that this is his first time doing the brakes on the car? i know i hate doing a job while having the whip up on jackstands/non-running and having to call someone up just to run to the parts store to get something i didn't realize i needed beforehand.
  1. 07 GXP Front Brakes
    By Fireof59 in forum Brakes/Suspension/Chassis
    Last Post: 05-24-2010, 05:14 PM
  2. Front brakes
    By MikeB91 in forum Brakes/Suspension/Chassis
    Last Post: 05-20-2010, 07:48 PM
  3. ls1 brakes up front
    By stanggreg90 in forum Brakes/Suspension/Chassis
    Last Post: 04-12-2010, 12:32 PM
  4. Installing front brakes
    By GPSims39 in forum Brakes/Suspension/Chassis
    Last Post: 06-29-2009, 09:48 AM
  5. F-Body front Brakes
    By TMC in forum Brakes/Suspension/Chassis
    Last Post: 01-19-2009, 11:49 PM
