Thread: Methanol Injection ?
Results 1 to 14 of 14
  1. #1 Methanol Injection ?
    GT Level Member AmericanRiceEater's Avatar
    New York
    Hey i not framiliar with using methanol injection. But today i was surfing through these forums and seen a devils own advertisement. I looked into their site and was looking at a stage 2 Methanol Injection kit for a GTP. My questions were is Methanol Injection a big benefit and worth the money? Also im not sure if i need any supporting mods to run this ? Thanks a lot.
    Black 2000 GTP Coupe. SSAutoChrome headers, K&N Cold Air Intake, Reptile Tuned PCM, 3.4" ZZP MPS, 104 Autolites & 180 Stat.
    PS3 Online: Zirpola (Dont use mic.)
  2. #2 Re: Methanol Injection ?
    id suggest doing a little searching on it.
    however, the consensus is that an intercooler is more effective, but meth/alky injection will be a shorter cost up front.
    ive ran it, but im not sure if given the option that i'd do it again.
  3. #3 Re: Methanol Injection ?
    New York
    Thanks bud ill do me some research.
  4. #4 Re: Methanol Injection ?
    Oct 2008
    Calgary, Alberta
    I did it cause I did not want to buy an intercooler yet, I am 1000m above sea level, and have a 3.5 " pulley,and tune opf ~ 5-12 degrees of timing wot, I did it to cool the intake slightly, and for the octane boost. It seems to work well for me.
    I am using:
    - devils own injector 5 gph- oversized I was told if using 100% methanol, I am using 20-40% methanol
    - a farm spay pump for 130 psi
    - a fuel pressure switch for nitrous safety set to 4-5 psi boost
  5. #5 Re: Methanol Injection ?
    DevilsOwn
    Guest
    Methanol injection is a proven power adder in so many applications. Its just very slow to catch on in this market. Its on tons of cobalts ss, buick gn, sti, evo, vw, audi, LS based apps. these can very easy cool better than even the best intercoolers for these.
    If you look on clubgp the vendors pushing against water methanol injection also produce intercoolers which has more markup for them. so you can see they are just looking after there pocket book.
    If you take my advice your going to make power
  6. #6 Re: Methanol Injection ?
    New York
    Im sure i will, ill message you when im interested in buying a kit. Are there full kits that include every last piece u need to install it?
  7. #7 Re: Methanol Injection ?
    Charles City, IA
    yes.
    SMGPFC Two Nipple General
  8. #8 Re: Methanol Injection ?
    DevilsOwn
    Guest
    yes it comes with eveything other than a tank. most people either use there washer tank or they buy a seperate tank from us or local. We don't force you into a tank.
  9. #9 Re: Methanol Injection ?
    Bastard Reptile's Avatar
    Kansas City, MO
    I run it, and I love it.
  10. #10 Re: Methanol Injection ?
    Apr 2009
    stockton ca
    hey reptile How bad is the tuning for meth Im going to drop to a 3.2 in aug and im picking up a tuner as well just curious
    I may need a little extra help for knock meth might be the answer
  11. #11 Re: Methanol Injection ?
    Kansas City, MO
    It's not too bad with a wideband, you end up pulling a little fuel in your PE tables, and then you can bump the timing way up.
  12. #12 Re: Methanol Injection ?
    Apr 2009
    stockton ca
    Ok doesnt sound bad ill get the 3.2 and tuner and see where im at with it
  13. #13 Re: Methanol Injection ?
    Apr 2008
  14. #14 Re: Methanol Injection ?
    Apr 2009
    stockton ca
    Ive been looking at it for over a year id already have it but my build ran over in price Ill get comfortable with the tuner first
  1. Interesting Article Describing Water/Methanol Injection
    By rynoman03 in forum General Tech Discussion
    Last Post: 02-19-2010, 07:36 AM
  2. Ask your water methanol injection questions here.
    By DevilsOwn in forum General Tech Discussion
    Last Post: 07-15-2009, 09:54 PM
  3. methanol injection questions
    By blessed in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-10-2009, 11:15 AM
  4. Methanol/water injection
    By gtp59 in forum General Tech Discussion
    Last Post: 04-01-2009, 09:59 PM
