Thread: DIC Question for 98-03
Results 1 to 14 of 14
  1. #1 DIC Question for 98-03
    SE Level Member christopher8911's Avatar
    North Carolina
    I got lucky today and found a DIC from a 1999 GTP for my 1998 GT. I started the install and found that I needed the harness since the plug-ins were different. The junk yard wouldnt let me cut the pigtail off when I went back to get it. What should I do? Can someone give me some info on where i can find the 24 pin connector?
    here is what i have:
  2. #2 Re: DIC Question for 98-03
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    pocket it at the junk yard i always pocket shiat
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  3. #3 Re: DIC Question for 98-03
    GTX Level Member Biohazed's Avatar
    Philadelphia, Pennsylvania, United States
    X2 pocket it .. I got lucky and got my pigtail from one of the guys on here then found the DIC on another forum .... but go into the local U-Pull-It and chop one out.... or I believe you can go to your local GM dealer and get a full pigtail but that way is pricey.
    *image too tall*
    BMR F + R Strut Bars - Falken Torque V 18's - JVC S900 - Kicker C10's - Spyder Projectors, Wizaird,
  4. #4 Re: DIC Question for 98-03
    GTP Level Member SuperSport's Avatar
    Michigan
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  5. #5 Re: DIC Question for 98-03
    Oh I just read your digital DIC is out of a GTP.. as far as I've read you should get one out of a GT or you may have issues with the TCS light ...
    read this:
    http://www.grandprixforums.net/f73/a...03-a-8171.html
    *image too tall*
  6. #6 Re: DIC Question for 98-03
    GTX Level Member noreasonwhyy's Avatar
    Michigan
    1. did you look just behind and down to the right of the DIC location? you may have the connector. it'd be covered by foam and in your dash by your glovebox
    2. if not, look for partouts in the for sale section, i'm sure just about any user parting out will be able to provide you with one for cheap
    3. if no luck, then do as SuperSport said and get one through morad
    4. i hope you let your junkyard know that was the last time they got business from you
    5. there's a how-to on how to fix the TCS light being on when it should be off and vice versa, maybe someone else can link you there seeing that i'm having no luck. or just search yourself, i'm pretty sure BackInBlack provided it
  7. #7 Re: DIC Question for 98-03
    Michigan
    Wow noreasonwhy is right...I didnt even think of that. The original poster has a 98, therefore he SHOULD have the plug in his dash when he removes his old DIC.
  8. #8 Re: DIC Question for 98-03
    North Carolina
    Quote Originally Posted by noreasonwhyy View Post
    Ill check for the other connector in the dash. Didn't think there would be one in the foam. Ill let y'all know what I find. Thanks for all the help and info guys.
  9. #9 Re: DIC Question for 98-03
    North Carolina
    Well I checked for the pigtail and came up empty. Guess I wasn't lucky enough to have it in my car. Guess I will have to order one from morad. Sucks
  10. #10 Re: DIC Question for 98-03
    Michigan
    Quote Originally Posted by christopher8911 View Post
    look again, it'd be tucked in to the right of the DIC/head unit/CC between there and the glove. 97s and 98s were wired for HUD and DIC because GTPs were an option rather than a trim package. if you don't have it, you've got a late built 98, i'd imagine. give it a nice look-see, i'd hate for you to have to splice when the connector's there all along.
  11. #11 Re: DIC Question for 98-03
    North Carolina
    Looked again. Removed the head unit for better visual. Still no pigtail. Guess I'm not that lucky. Ill check again in the daylight. The build date for the car is 03/98
  12. #12 Re: DIC Question for 98-03
    North Carolina
    Ok I picked up a harness from the pick and pull. Doing some reading and it seems as though I need to run a wire from the instrument cluster to the dic. Is that right? If so, which one? I can't seem to find the thread that I saw it in.
  13. #13 Re: DIC Question for 98-03
    its one of the green wires on the Natural plug of the gauge cluster. I have to look at my plug out guide I have.
    *image too tall*
  14. #14 Re: DIC Question for 98-03
    North Carolina
    Natural plug? Is this the plug going into the rear of the IC? Sorry for so many questions but I want to be shure I get it right the first go around.
  1. FWI(fender well intake) question. Exhaust(cat) question.
    By DJspinner in forum General Tech Discussion
    Last Post: 01-23-2010, 01:47 AM
  2. Vacume Tree question & Pcv question
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2009, 01:14 AM
  3. Question: Supercharger question.....
    By nmaponte in forum General Tech Discussion
    Last Post: 03-12-2009, 01:04 PM
