Thread: swapping an ls4 into a 97-03 gp
Results 1 to 20 of 23
  1. #1 swapping an ls4 into a 97-03 gp
    SE Level Member NineD9GT's Avatar
    Dec 2008
    PA
    Has anyone tried this yet? I don't think it would be that hard. I spun a bearing in my l67 that I swapped into my 99GT, now I'm looking at my options. Got drinking a couple last night, and bs'ing. "Hey, what's stopping you from swapping an ls4 into that hog?" I said "hmmm, I guess not having one right now." I'm 90 percent sure it will fit. Would be nice if the whole cradle would bolt up. Just an idea right now, what do you guys think?
    99 GP GT L26 bottom end, Intense stage II cam, Ported L67 heads w/ LS6 springs, LS1 valve seals, 42.5# injectors, ported sc/intake, custom LS1 TB and MAF, custom FWI, 3.4 mps, NGK TR6, ZZP wires, 180 stat, etc...
  2. #2 Re: swapping an ls4 into a 97-03 gp
    Troy OH
    the idea has crossed my mind as well, i think it would be a pretty nice sleeper. i haven't looked into the ways to actually do it though. the biggest drawbacks that come to mind would be extra strain on the transmission and a small aftermarket for the ls4. i'm sure you could build an l67 that makes more power than an ls4 pretty easily, just don't know about price. i think it's worth looking into
  3. #3 Re: swapping an ls4 into a 97-03 gp
    Dec 2008
    PA
    Well, I would swap the 4t80e in with it. I was thinking of doing the swap, and keeping the 5.3 in long enough to work out the bugs. Then, swap in a ls1 or ls2. You can pick up a 6.0 around here pretty cheap out of a truck. I think that would get work done.
  4. #4 Re: swapping an ls4 into a 97-03 gp
    Portland Oregon
    I think an LS2 or LS1 would probably be easier. That way you wouldn't have to worry about DOD
  5. #5 Re: swapping an ls4 into a 97-03 gp
    Troy OH
    haha oh yeah, that would do work. you'd be sitting at an intersection just spinning the tires when the light turns green. didn't they shorten the crankshaft or something to fit the ls4 for transverse applications? an ls1 or 2 would probably have a lot more fab work. totally worth it.
  6. #6 Re: swapping an ls4 into a 97-03 gp
    Dec 2008
    PA
    My friend does computer tuning, so he could just eliminate that. I think I'm going to have to do this. Now, I'm getting excited. haha
  7. #7 Re: swapping an ls4 into a 97-03 gp
    someone on here is swapping in an ls4 and just swap the LS4, cam it (get rid of DOD), LS6 intake, TEP tranny and you should be good to go.
  8. #8 Re: swapping an ls4 into a 97-03 gp
    GT Level Member sic6's Avatar
    san marcos, tx
    The crank ends are machined to fit in the w body application. The front accessories are also slimmer than typical Ls engines to provide clearance. As far as mods goes if you don"t mind getting rid of D.O.D then you can basicly mod it just like a Ls engine, heads, cam, certain intake manifolds and other mods. You could also overbore the cylinders to get 5.7 displacement since the 5.3 and 5.7 have the same stroke. You will be limited however by header design due to the fwd layout. I say do it, it will be a fun project to do.
  9. #9 Re: swapping an ls4 into a 97-03 gp
    GTX Level Member 03GTPLE's Avatar
    Tyler, TX
    Here's the link on someone that did it a looong time ago. Tom K of Texas is the proud owne
    pic:
    2003 White Grand Prix GTP Limited Edition
    - 3.4 pulley, tune by Boostd1/CLINT@AIR, Short Ram Intake, PLOG, 3" ZZP Downpipe, AL 104's, 180* t-stat, Impala STB & 12" cross drilled/slotted/zinc washed rotors, DDM HID's, and put in a heads up display for now...
  10. #10 Re: swapping an ls4 into a 97-03 gp
    Tyler, TX
    here's gm's version of an LS1 in a 99 Impala SS (prototype)
    LS-1 Powered Impala SS - Feature - GM High-Tech Performance
  11. #11 Re: swapping an ls4 into a 97-03 gp
    GTP Level Member SuperSport's Avatar
    Michigan
    Quote Originally Posted by 03GTPLE View Post
    Ive personally driven that exact car. My dad was on that project. They did a 00 Monte SS with the LS1 too.
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  12. #12 Re: swapping an ls4 into a 97-03 gp
    SE Level Member hklvette's Avatar
    Jun 2010
    Christiansburg, VA
    The LS4 uses a different bellhousing pattern than the other V8s. Fiero guys using LSxs use adapter plates, but they always bolt up to manual transmissions. Not sure what issues you run into trying to use an automatic. Also, the starter for the LS4 is mounted on the transmission if i'm not mistaken.
    '05 silver GTP, '98 Cherokee, '78 M880, '70 M35A2
    "Drag racing is for fast cars. Autocross is for fast drivers."
  13. #13 Re: swapping an ls4 into a 97-03 gp
    You think Torque steer is bad with a 3800...LOL at a V8. I'll still win in my V6 car. Good luck.
  14. #14 Re: swapping an ls4 into a 97-03 gp
    May 2008
    staten island,NY
    its a waste of time and money, you need to rewire the car for it to use the CAN bus because the engine is not OBD2. also that engine puts out A LOT of heat, factory GXP's come with 6* of KR or more from the factory, not to mention 210* IAT's and over 250* coolant and trans temps after a few WOT runs. a 3800 with a blower is cheaper and faster than a 5.3, you want an LS buy an F-Body
  15. #15 Re: swapping an ls4 into a 97-03 gp
    Dec 2008
    PA
    Just trying to be different. F bodies are a dime/dozen. How many 97-03 v-8 grand prixs do you see? *still in research mode, but I think I need to try it.
  16. #16 Re: swapping an ls4 into a 97-03 gp
  17. #17 Re: swapping an ls4 into a 97-03 gp
    Troy OH
    if you're not trying to drive it everyday, and you got the money to do it, i don't see why not lol. it would be fun to do
  18. #18 Re: swapping an ls4 into a 97-03 gp
    buy a GXP already....
  19. #19 Re: swapping an ls4 into a 97-03 gp
    can I put an S52b32 in my GP?
  20. #20 Re: swapping an ls4 into a 97-03 gp
    NO DAMNIT!
    jeeez.
  1. Top Swapping I have questions.
    By GAFF in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-30-2010, 10:17 AM
  2. Swapping '03 radio for '04-'08
    By rpenling in forum Audio, Security & Visual Electronics
    Last Post: 03-21-2010, 10:28 PM
  3. Swapping engines
    By dbz09 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-06-2009, 12:51 PM
  4. Swapping PCM's
    By Clar2478 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-08-2009, 09:34 PM
  5. 99 GTP vs. 97 GT Swapping Parts
    By Bandit1228 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-19-2009, 09:40 AM
