Thread: Inter. Fan motor runs w/out key
Results 1 to 18 of 18
srspicer Inter. Fan motor runs w/out... 06-01-2010, 12:31 PM
srspicer Re: Inter. Fan motor runs... 06-02-2010, 11:41 AM
shawngtp Re: Inter. Fan motor runs... 06-02-2010, 11:44 AM
sic6 Re: Inter. Fan motor runs... 06-02-2010, 02:56 PM
srspicer Re: Inter. Fan motor runs... 06-02-2010, 05:51 PM
CTKGP09 Re: Inter. Fan motor runs... 06-02-2010, 10:03 PM
srspicer Re: Inter. Fan motor runs... 06-03-2010, 06:15 AM
srspicer Re: Inter. Fan motor runs... 06-03-2010, 06:19 AM
sic6 Re: Inter. Fan motor runs... 06-05-2010, 01:51 PM
rynoman03 Re: Inter. Fan motor runs... 06-06-2010, 07:16 AM
srspicer Re: Inter. Fan motor runs... 06-07-2010, 09:00 AM
Abrasive Re: Inter. Fan motor runs... 06-08-2010, 12:37 AM
srspicer Re: Inter. Fan motor runs... 06-09-2010, 08:06 AM
srspicer Re: Inter. Fan motor runs... 06-24-2010, 06:44 PM
sic6 Re: Inter. Fan motor runs... 06-27-2010, 02:29 AM
  1. #1 Inter. Fan motor runs w/out key
    PA
    Hello All,
    Its been a while. My first posting here was about a coolant leak that was hard to find. Turns out it was the PLASTIC coolant elbows.
    New problem; I went out to the car to roll up windows and found the radio on, interior fan running. I put the key in and started the engine, turned it off, moved key from acc. to on and no change. Had to disconnect the battery to shut the fan off. ? Can I assume it is a bad ignition mech?
    ( 2002 3.8 V6, automatic all stock.)
    Thanks in advance for any help/suggestions.
    (Also, is there a thread on why the hell the tail lights are de-laminating and replacements? Talk about cheap!)
  2. #2 Re: Inter. Fan motor runs w/out key
    PA
    Not a single suggestion?
  3. #3 Re: Inter. Fan motor runs w/out key
    Nov 2009
    Grand haven
    Quote Originally Posted by srspicer View Post
    Hello All,
    This ^^^^
  4. #4 Re: Inter. Fan motor runs w/out key
    GT Level Member sic6's Avatar
    san marcos, tx
    Your ignition switch could be causing the problems. It might be going bad or the RAP module or relay could be going bad as well. THe RAP is what temporarily keeps your accessories powered up when you remove your key from the ignition until you open your door or exceeds the preset time, then shuts off.
  5. #5 Re: Inter. Fan motor runs w/out key
    PA
    Thanx sic6.
    Are you talking about a main relay or a smaller one, and pardon the ignorance, but what does R A P stand for? I am still new to doing my own work on this car. My CRX I understand, but this vehicle is way more complicated.
    Any way to eliminate these by simple checks, or is replacing one by one the only way to do it?
    Thanks in advance.
    Scott
  6. #6 Re: Inter. Fan motor runs w/out key
    Willoughby, Ohio
    you can tint your tail lights to solve that problem
  7. #7 Re: Inter. Fan motor runs w/out key
    PA
    Thanks CTKGPO9,
    But tinting won't eliminate the cracks that are appearing. What cheap crap!
  8. #8 Re: Inter. Fan motor runs w/out key
    PA
    Another point I forgot about was that the fan speed selector would not shut off the fan! (DUH) I forgot about that until I looked at it again. I guess that is another part that is wearing out.
  9. #9 Re: Inter. Fan motor runs w/out key
    san marcos, tx
    Try pulling the fuses for the components that stay on. If they still stay on after you pull the fuse then you my friend have a short to power somewhere in the car which is keeping everthing on.
  10. #10 Re: Inter. Fan motor runs w/out key
    PA
    Pulled the hvac cntl fuse. That shut the blower off so I could quick charge it to start
    Scott
  11. #11 Re: Inter. Fan motor runs w/out key
    Topeka, KS
    There's another member that's having the same problem on our local board. www.kcpmc.net you're not alone. My guess is it's something in your HVAC control.
  12. #12 Re: Inter. Fan motor runs w/out key
    PA
    Thanks rynoman03,
    I'll check it out. Can you tell me under which topic the subject is before I join to view it?
    It is the interior fan guys, not the radiator fan.
    Thanks for the help!
    Scott
  13. #13 Re: Inter. Fan motor runs w/out key
    Odessa, MO
    Blower motor resistor seems to be the common cause of this according to the thread at KCPMC.
  14. #14 Re: Inter. Fan motor runs w/out key
    PA
    Thanks Abrasive, but does that account for the radio staying on as well?
    Thanks,
    Scott
  15. #15 Re: Inter. Fan motor runs w/out key
    PA
    Okay,
    Well to sum up, it was the relay. It had to be pulled and replaced. The part cost about $70.00! It had melted and shorted out.
    Thanks for the help, everyone!
    Regards,
    Scott
  16. #16 Re: Inter. Fan motor runs w/out key
    san marcos, tx
    Glad you found the problem and ouch! 70 for a relay.
  1. First runs at the strip
    By Space Dynamics in forum Track Sessions and Kills
    Last Post: 04-29-2010, 09:25 PM
  2. GTP Runs too lean
    By turk182 in forum Off Topic Discussion
    Last Post: 09-17-2009, 11:30 AM
  3. car runs hot?
    By chuy09 in forum General Tech Discussion
    Last Post: 05-31-2009, 08:36 AM
  4. Blower motor runs but no/little air comes out.
    By bradford82 in forum General Tech Discussion
    Last Post: 01-13-2009, 05:58 PM
  5. WTF new Infiniti SUV runs 13.5's!!!
    By Smokin2000gtp in forum Off Topic Discussion
    Last Post: 11-23-2008, 07:02 PM
