Thread: heated seats problem
Results 1 to 4 of 4
  1. #1 heated seats problem
    SE Level Member Ryansgtp's Avatar
    Jul 2010
    Medina NY
    When I bought the car the heated seats did not work. I checked the fuse, which is fine. Could it be the switch or the motor? How can you tell?
  2. #2 Re: heated seats problem
    SE Level Member RideMr2's Avatar
    Memphis
    I would check the switch, make sure it's working. It should pop out, and you can check it with a meter.
    No motor, it has a ceramic element inside your leather seat. The element can wear out, and break over time.
  3. #3 Re: heated seats problem
    Jul 2010
    Medina NY
    When I turn it on high/low it still lights up but just doesn't do anything. Could it still be the switch if it lights up?
  4. #4 Re: heated seats problem
    GTX Level Member Rather B Blown's Avatar
    Dec 2008
    London, Ontario
    yes test it with a multimeter
    Quote Originally Posted by Reptile
    It sounds like you accidentally stuffed a midget in the downpipe, and he's hammering out an SOS to get out.
  1. heated seats
    By Will5600 in forum General Tech Discussion
    Last Post: 01-29-2010, 02:24 PM
  2. My heated seats didn't shut off?
    By Silent Drifter in forum General Tech Discussion
    Last Post: 12-03-2009, 01:39 AM
  3. Heated seats + Burning Smell?
    By xerxescct in forum General Tech Discussion
    Last Post: 01-25-2009, 11:31 PM
  4. Dual Heated Seats in the 97-2003's?
    By nathangartz in forum General Tech Discussion
    Last Post: 01-22-2009, 11:28 AM
  5. Heated Seats
    By 02BlueGT in forum General Tech Discussion
    Last Post: 01-20-2008, 02:49 AM
