Thread: Help locating resistor on blower motor
Results 1 to 9 of 9
  1. #1 Help locating resistor on blower motor
    SE Level Member NoTyme's Avatar
    southeast Michigan
    I need help locating resistor on blower motor... I have pulled the glove box, both panels above the feet area and can't find it anywhere... 02 GP with dual heater controls... Someone's got to know where it is!!!
    Unless NAPA gave me the wrong part I don't see it!
  2. #2 Re: Help locating resistor on blower motor
    GTP Level Member lambokit's Avatar
    Apr 2009
    Radford, Virginia
    Oh yeah, it's a pain in the a$$. Follow the wire located at the back of the blower.fan motor. It's on the main back where the floor board and firewall meet. It's really tight. I think it's a 7mm or 8mm socket. Just take your time and a deep breath, count to 10 every time you get pissed off. There are 2 screws that hold it in. Good luck.
    Lambokit to be built!!!!!
  3. #3 Re: Help locating resistor on blower motor
    southeast Michigan
    Quote Originally Posted by lambokit View Post
    Follow the wire located at the back of the blower.fan motor. It's on the main back where the floor board and firewall meet. It's really tight. I think it's a 7mm or 8mm socket. There are 2 screws that hold it in. Good luck.
    Holy crap!!! You ain't kidding on the tight fit. There are 2 screws on the back side up next to the firewall and one of the cab facing side. Me and the wife have been working on it and had to take a break... I can't get my fat fingers up in there.
    You need to cut some of the sound deaden-er away to get to the screws. What a poor design.
  4. #4 Re: Help locating resistor on blower motor
    Quakertown, PA
    I also have a '02 GT and replaced my blower resistor last year. It's a real PITA, but can be done. Here's a link with pictures on how to do it.
    Ontario Quebec Club Grand Prix :: Fan resistor replacement
    The hardest part was twisting my body around enough to get my fat fingers back there. I ended up with a twisted knee that hurt me for over 2 months.
    '02 - 3.8(K) 153,000 miles, New UIM, New LIM alum. gasket, new lifters, new OEM cat. Runs great ! Owned it since new. (bought it 12 years ago with only 22 miles on the clock)
  5. #5 Re: Help locating resistor on blower motor
    GT Level Member Madness's Avatar
    Nov 2009
    A little late
    ^^^ nice link
    Favorite Quote: You can't fix stupid!!
    http://www.youtube.com/watch?v=0gxKStPXyn8
  6. #6 Re: Help locating resistor on blower motor
    Donating Users
    South Deerfield, MA
    I've done two of these and I agree, they are a PITA! I found it easiest to use a 1/4" drive ratchet and press it hard into the floor padding to get it to line up straight on the small bolt. I even considered pulling the front seat out just so I didn't have to lay upside down with my back over the door sill.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  7. #7 Re: Help locating resistor on blower motor
    Nov 2009
    A little late
    ^^ yes, the 1/4 ratchet helps, i have a "request" to do another one for a friend and am going to buy a 1/4 swivel to put between the socket and socket extension, hope it helps!!
  8. #8 Re: Help locating resistor on blower motor
    Quakertown, PA
    The tool I used to get at the back screws is a flexible shaft 1/4" drive screwdriver. You know, the kind that looks like a screwdriver with a 1/4" drive on the end, but the shaft is a flexible one that can bend. Very handy for those tight spots.
  9. #9 Re: Help locating resistor on blower motor
    Charles City, IA
    ^ get one of those. Loosen the two screws you can see then just pull it out. You do not need to loosen all three. Then before you put the new one in you just loosen the third one up so it can slide under it.
    SMGPFC Two Nipple General
  1. Blower Motor Resistor
    By SyntheticShield in forum General Tech Discussion
    Last Post: 09-29-2017, 04:39 PM
  2. Blower Motor Resistor
    By kingbrentdwyer in forum General Tech Discussion
    Last Post: 02-28-2014, 05:34 PM
  3. blower motor resistor
    By hacket in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-22-2010, 11:40 AM
  4. Replaced Blower Motor Resistor:(
    By lambokit in forum The Rant Forum
    Last Post: 10-17-2009, 02:31 PM
  5. The Old and The New, Blower Motor Resistor
    Last Post: 01-29-2008, 12:31 PM
