Thread: E 85
Results 1 to 7 of 7
  1. #1 E 85
    Edmond
    Just wondering if anyone knows exactly what it takes to make the switch over to E85. Besides the larger Injectors and a tune, is there anything else necessary?
  2. #2 Re: E 85
    gm says otherwise.... but most people say thats about it.
    just drain the system and change the fuel filter.
  3. #3 Re: E 85
    Joliet, IL
    injectors, tune, and alot of fuel filters when you first switch.
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  4. #4 Re: E 85
    Edmond
    How do you think a mini afc would do for the initial tuning?
  5. #5 Re: E 85
    Topeka, KS
    Probably not very good. But you never know. I'd go for personalized tune. I mean the AFC's did the trick back in the day but you can't beat a personalized tune. Plus with E85 you can probably add more timing
    I think you also need a bigger fuel pump. You might check into that though.
  6. #6 Re: E 85
    you'd have to skew with an AFC a lot in order to get it to work. a tuner is what you need considering you'd need new injector maps.
  7. #7 Re: E 85
    Edmond
    I wasn't really sure what all it took. I don't have a tuner, but I do have a PCM with adjustable timimg "Happy Knob" I have this from back in the day when my car was actually fast.... I also have an AFC, so was just wondering. E85 wasn't ever an option before but a couple more places near by have started carrying the gas so I guess its an option now. I guess I need to look into the fuel pump issues.
