Re: Speed Daddy Header install writeup
didnt read all the way through so sorry if i missed it but spend 6 bucks when you get these and get a set of gaskets from autozone as the ones i got with mine werent even close to the right size...major headache also i had a problem with the lower clamp hitting the lines for my power steering and the tubes were too close together...since u cant take them apart after clamping anyways i just found it far easier to buy a flang kit and welded everything together...i hate exhaust clamps
You didnt say anything about the EGR?
Whats EGR? :D
You can install it. But its a whore and will probably leak.
You can create block off plates using the flanges off of the EGR tubes, pennies and copper RTV.
update... i just got a set of SD headers and they are great. the gaskets that came with it mounted and fit perfect on my 98 L36. the cross over pipe fits nice and tight... almost too tight as it is hard to assemble on the engine but would rather fight to get it in and know it is sealed. i will be going back and upgrading the clamps, as even if the crappy U clamps work i just dont like them! but after reading about how loose the pacesetter pipes were and the sealing issues... its good to see these fit great.
