Thread: Can't get my key out of the ignition!!!
Results 1 to 8 of 8
  1. #1 Re: Can't get my key out of the ignition!!!
    GTX Level Member 03GTPLE's Avatar
    Tyler, TX
    there's a little button underneath the steering column you can push with a screw driver after you get the cap off. It'll let your key come out. Easiest way to fix it is to zip tie the button down. Mine's worked great for over a year now. If I recall correctly, three torx screws gets the lower half of the cover off.
    ...otherwise you replace the solenoid....
    2003 White Grand Prix GTP Limited Edition
    - 3.4 pulley, tune by Boostd1/CLINT@AIR, Short Ram Intake, PLOG, 3" ZZP Downpipe, AL 104's, 180* t-stat, Impala STB & 12" cross drilled/slotted/zinc washed rotors, DDM HID's, and put in a heads up display for now...
  2. #2 Re: Can't get my key out of the ignition!!!
    Aug 2008
    Iron Mountain, MI
    thank you very much for the info. that worked perfect.
  1. ignition switch help
    By redrivergar in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-02-2010, 09:13 PM
  2. I can't take my key out of the ignition!
    By Deezul_AwT in forum General Tech Discussion
    Last Post: 09-06-2010, 11:10 AM
  3. Replies: 1
    Last Post: 02-01-2010, 10:18 AM
  4. Ignition advance
    By GTPRiley in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-28-2009, 08:12 PM
  5. Need More Help, Ignition
    By SyntheticShield in forum General Tech Discussion
    Last Post: 01-28-2008, 12:17 AM
