Thread: what is ignition advance
Results 1 to 8 of 8
  1. #1 what is ignition advance
    SE Level Member xsvtank's Avatar
    NJ
    hey guys i have a obd tool/scanner and i was looking at live data is ign advance how much KR i am getting or are they 2 different?
  2. #2 Re: what is ignition advance
    more timing advance makes more chance for knock, but they are two different readings.
    timing advance is how soon before top dead center that the spark plug lights the gas/air in the combustion chamber.
    KR, or knock retard is the car pulling timing in order to prevent detonation (pinging). detonation will blow your motor if not kept in check. if KR is present, so is detonation because its a reaction to it.
  3. #3 Re: what is ignition advance
    NJ
    what is the ideal timing advance for these cars?
  4. #4 Re: what is ignition advance
    usually anything above 18* on the street is fairly pointless, but you start running into diminishing gains in the 22* area. just remember, timing is 'free' power while boost is not.
  5. #5 Re: what is ignition advance
    NJ
    im at 20* ad ilde and the cars stock...
  6. #6 Re: what is ignition advance
    we mean at wide open throttle.
    These cars can run up to 50 * of timing advance if under very light throttle.
  7. #7 Re: what is ignition advance
    NJ
    ohh alrighjt ill drive it tmro and take a look
  8. #8 Re: what is ignition advance
    Jersey
    i run around 30ish on the highway and 14* wot on a 3.6
    16' wrx sti- stock
  1. Advance sale on OBD II scanners
    By Madness in forum General Tech Discussion
    Last Post: 05-20-2010, 09:35 PM
  2. advance auto sale (today only)
    By noreasonwhyy in forum Off Topic Discussion
    Last Post: 05-16-2010, 10:08 PM
  3. Ignition advance
    By GTPRiley in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-28-2009, 08:12 PM
  4. key won't advance in ignition - won't trun
    By Michael Lomb in forum General Tech Discussion
    Last Post: 04-20-2009, 11:35 AM
  5. what to expect with timing advance
    By TehGTP in forum PCM Tuning
    Last Post: 12-07-2008, 08:05 PM
