Thread: how to splice l67 injectors into a 01 gt
Results 1 to 9 of 9
  1. #1 how to splice l67 injectors into a 01 gt
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    well im top swapping my 01 and the conectors are diffrent then my 97 l67 injectors just want to know what color goes to what thanks im pretty sure i got it figured out just want someone to confirm
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  2. #2 Re: how to splice l67 injectors into a 01 gt
    HUDSON
    All you have to do is get any Haynes repair manual and check to see which color is -, andwhich is +, usually with injectors it does not matter, they will work either way.
    Basically, you should be able to get away with just connecting the wire, I suggest first connect with a good crimp tool, and the solder the crimp connection, then heat shrink, them cover with the corregated tubing, that how I have done all my injectors on my projects.
    Dean
  3. #3 Re: how to splice l67 injectors into a 01 gt
    ya i just looked at the wireing and one wire has a black strip so that got to be ground and the other is just a solid color as for connecting them i was gunna twist them solider them thet heat shrink them
    sold 97 GTP stock
  4. #4 Re: how to splice l67 injectors into a 01 gt
    Charles City, IA
    Does not matter. They are just a coil of wire.
    SMGPFC Two Nipple General
  5. #5 Re: how to splice l67 injectors into a 01 gt
    May 2008
    staten island,NY
    get the harness and connectors from ZZP, all the colours match
  6. #6 Re: how to splice l67 injectors into a 01 gt
    $10 for yard connectors or $45+ shipping for ZZP ones...
  7. #7 Re: how to splice l67 injectors into a 01 gt
    HUDSON
    I just getthem from the junk yard too, CHEAP!
  8. #8 Re: how to splice l67 injectors into a 01 gt
    GT Level Member GeosGP's Avatar
    Fenton, MI
    Just make sure to do a good job soldering the wires, and use heat-shrink tubing. It's your friend.
    2004 Grand Prix GTP Comp-G
    Stock, featuring more KR than you can shake a stick at
  9. #9 Re: how to splice l67 injectors into a 01 gt
    ya im just gunna use the conectors that came with the injectors im not spending 45 buck if i dont have to
    sold 97 GTP stock
  1. do i need to get injectors?
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-04-2010, 05:48 PM
  2. 42# injectors on an 04
    By Infinity9999 in forum PCM Tuning
    Last Post: 08-17-2009, 12:31 PM
  3. 42.5# injectors?
    By fst in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-06-2008, 02:17 PM
