Thread: Fuel Pump won't run when engine does
Results 1 to 12 of 12
  1. #1 Fuel Pump won't run when engine does
    Jun 2010
    Woodland WA
    Please help
    1997 Pontiac Grand Prix GTP 3.8L supercharged
    New fuel pump; changed computer, changed fuel filter, changed fuel pump relay
    Symptoms:
    Scenario 1:
    Key on – fuel pump starts for 2 sec. –pressures rack to 52 lbs-then shuts off (normal)
    Car starts – computer says “fuel pump on” (normal)
    Fuel pump has no power going to it- fuel pressure falls off-car dies
    As soon as car dies the fuel pump pressures up and shuts off.
    This cycle repeats.
    At first after the car would cool down- it would run for a while before stalling
    Scenario 2:
    Car starts – accelerator is held to the floor
    Rev limiter stalls engine at 4000 rpm
    Engine slows to about 3000 rpm
    Then speeds up to 4000 and stalls
    This cycle takes less that 1 sec.- repeats until-
    Gas pedal is released, then engine slows down and dies
    Fuel pump starts pumps for 2 sec and shuts off
    Manual says after the initial 2 sec pump to charge system – the computer waits (while cranking) to receive a “signal” (from where it doesn’t say) to send the “on voltage” to the pump relay. In another place says comp. sends a signal to another before the actual pump relay.
  2. #2 Re: Fuel Pump won't run when engine does
    Pa
    i am having the same problem, have u found the solution yet
  3. #3 Re: Fuel Pump won't run when engine does
    GT Level Member gpbastard's Avatar
    Florida
    Quote Originally Posted by jdonald View Post
    Please help
    Symptoms:
    Scenario 1:
    This cycle repeats.
    Scenario 2:
    this sounds like a fuel pump resistor that's bad. a common problem on these cars.here's a link that might help:Rocky Mountain Club Grand Prix
    gpbastard
  4. #4 Re: Fuel Pump won't run when engine does
    Charles City, IA
    Is your security light flashing?
    SMGPFC Two Nipple General
  5. #5 Re: Fuel Pump won't run when engine does
    Jun 2010
    Woodland WA
    I fixed it. It wasn't the resistor. The signal from the computer wasn't reaching the resistor relay. I shunted the two prongs on the resistor relay so the fuel pump does not run on low speed. It runs at "normal" speed all the time. It works perfect now.
  6. #6 Re: Fuel Pump won't run when engine does
    Florida
    it runs on high speed now and that's hard on your fuel pump. i still think it's the resistor...
    gpbastard
  7. #7 Re: Fuel Pump won't run when engine does
    Florida
    you understand that this is only a temporary fix don't you? here's a link you might want to look at: 97' GTP Starts then Stalls - GM Inside News Forum
    gpbastard
  8. #8 Re: Fuel Pump won't run when engine does
    Jun 2010
    Woodland WA
    I shunted the resistor wires to bypass it and the fuel pump would not run. So, I don't think it's the resistor.
  9. #9 Re: Fuel Pump won't run when engine does
    Florida
    did you have the new computer reflashed?...
    gpbastard
  10. #10 Re: Fuel Pump won't run when engine does
    Jun 2010
    Woodland WA
    No I didn't, how does that affect the operation?
  11. #11 Re: Fuel Pump won't run when engine does
    Pa
    I found my problem that had similair simptons and it turned out to be a broken wire on the back of the fuse panel for the pcm and sensor ground. Check the black and white wires coming from B1 and B3 in the black cell. Only after replacing both cam and the crank sensor and bench testing the harness for shorts, did i realize that when i was playing with the warness i was bumping the fuse panel which allowed the car to start until i hit a bump
  1. Fuel issue...possible fuel pump????HELP
    By TAWinner23 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-31-2013, 11:50 PM
  2. Fuel Pump won't run when engine does
    By jdonald in forum Introductions/Noob Questions
    Last Post: 06-14-2010, 01:53 AM
  3. Fuel pump / Fuel sender question !
    By 2001redfireGT in forum General Tech Discussion
    Last Post: 03-01-2010, 11:03 AM
  4. Fuel pump whine when engine gets hot
    By Skeeve in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-02-2009, 02:23 PM
