Thread: 98 GTP Trouble starting while cold
Results 1 to 11 of 11
  1. #1 98 GTP Trouble starting while cold
    Bay area, California
    Im having a trouble starting my car in the morning. Sometimes it wil start then die. Then when i try it again it wont start unless i give it gas but then it will die unless i keep giving it gas. After about 5-10 of warming up everything is fine just idles low.
  2. #2 Re: 98 GTP Trouble starting while cold
    Iowa
    bad fuel pump? maybe. you could need a better battery?
  3. #3 Re: 98 GTP Trouble starting while cold
    ok but i dont think its the fuel pump because after its been driven for about 30 mins its ok an starts right up and has full power when i floor it.
    my only problem is starting it while it cold it will die or wont start unless i give it gas
    but when i release off the gas it dies. I have to keep my foot on the gas to warm it up or else it will die.
    When its warm some times it wont start but when i give it gas it wont die after that it will idle just fine.
  4. #4 Re: 98 GTP Trouble starting while cold
    After driving it today for about an hour, if i park it and let it sit for about 15 minutes it sometimes will idles low like around 600 but then it will go away after a few minutes and idle normal. Could it be an injector?
  5. #5 Re: 98 GTP Trouble starting while cold
    Willoughby, Ohio
    MAF sensor needs cleaned or replaced, happened to me too
  6. #6 Re: 98 GTP Trouble starting while cold
    If its the MAF sensor why does it not start cold unless i give it gas and i have to
    keep my foot an the gas or it will die. Even sometimes when its warm i have to give
    it gas to start but i dont need to keep my foot on the gas like i do at cold starts.
  7. #7 Re: 98 GTP Trouble starting while cold
    Willoughby, Ohio
    idk why its does that but mine did the excact same thing, try unplugging it and see if it dies then, if it runs better then the MAF is dirty or bad
  8. #8 Re: 98 GTP Trouble starting while cold
    looks fast.... its slow:) beckys2000gt's Avatar
    Nov 2009
    stoystown, pa
    mine did the same, had 2 guys cleaning my maf at the meet, start everytime now thanks guys
  9. #9 Re: 98 GTP Trouble starting while cold
    GTP Level Member SuperSport's Avatar
    Michigan
    The Idle Air Controller was bad in mine. Was causing the same exact symptoms. That fixed it for me.
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  10. #10 Re: 98 GTP Trouble starting while cold
    Thanks SuperSport I think that was the problem. I cleaned up my idle control vavle and every since its been stating up every morning without me pressing on the gas for it to start an stay running on cold starts.
    Thanks you guys
  11. #11 Re: 98 GTP Trouble starting while cold
    Michigan
    No problem. Sometimes its the simplest (and cheapest) solutions that fix issues.
  1. Starting to Mod
    By NewPrixOwner666 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-08-2009, 05:04 AM
  2. Starting problem....
    By greatAEorion in forum General Tech Discussion
    Last Post: 09-30-2009, 09:54 AM
  3. having trouble starting my car
    By gonzo915gp in forum General Tech Discussion
    Last Post: 08-04-2009, 03:47 PM
  4. starting car trouble
    By rochaedkj in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-17-2009, 01:12 AM
  5. trouble starting, misfire
    By Toasty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-16-2008, 11:55 PM
