Thread: De-badge
Results 1 to 11 of 11
  1. #1 De-badge
    SE Level Member prixgt01's Avatar
    Schaumburg,il
    Id figure id ask you guys before i went ahead and did it and messed things up. whats the best way to de-badge the car, with what tools. thanks.
  2. #2 Re: De-badge
    GT Level Member CMURDAx's Avatar
    Toledo, Ohio
    i used a blow dried, ripped em off then a plastic mixing blade to get them off, then mineral spirits to take the rest of the glue off. i didnt have any color difference from where they were and i have a 2000, and i just did mine in like nov 2009.
  3. #3 Re: De-badge
    Florida
    When I took the badge off my trunk, I used some fishing line to actually get the badge off, then used a heat gun to soften the adhesive, and managed to get it all off in about 5 minutes. After a good wash you couldnt tell it was ever there. I took it off last Fall, so it was on the car for 7+ years.
  4. #4 Re: De-badge
    Apr 2009
    stockton ca
    heat it up and use something non maring or fishing line then goof off or mineral spirits something along those lines
  5. #5 Re: De-badge
    MA
    or you could use the search button
    SMGPFC Member #9
  6. #6 Re: De-badge
    looks fast.... its slow:) beckys2000gt's Avatar
    Nov 2009
    stoystown, pa
    autozone has sticker lifter, comes with a little tool $6.99, worked awesome, no scratches........... i think the brand is goo-gone
  7. #7 Re: De-badge
    Schaumburg,il
    thanks for all the reply's, except silverman...j/k if it stops raining over her i'll post up some pics later
  8. #8 Re: De-badge
    SE Level Member RustedOutBuick's Avatar
    Charlotte,NC
    I used a bit of heat to pull the badge off, then WD-40 to get the glue off. WD-40 takes that glue stuff off anything..
  9. #9 Re: De-badge
    Willoughby, Ohio
    just pick them off with your fingers and use rubbing alcohol to get the residue off and wash the area after, eeeaasssyyyyy
  10. #10 Re: De-badge
    Schaumburg,il
    Sweet thanks guys it finally stopped raining here and ill get to it.
  11. #11 Re: De-badge
    MO
    i use fishing line to "saw" throught he goop, then use goof off to get the residue off. Works like a charm.
    <brandonl2000> LMAO D!!
  1. badge ?'s
    By clevelandfan in forum Visual/Body Modifications
    Last Post: 05-27-2010, 10:28 PM
  2. lol new badge....
    Last Post: 05-04-2010, 02:02 PM
  3. Arrowhead Badge
    By J_Man55 in forum Visual/Body Modifications
    Last Post: 06-19-2008, 01:28 PM
  4. looking for gtp badge
    Last Post: 01-12-2008, 10:44 PM
