Thread: Key intermittently won't come out of ignition
Results 1 to 8 of 8
  1. #1 Key intermittently won't come out of ignition
    Stouffville, ON
    Hey guys,
    01 GTP, 4 door, fully loaded.
    I have an intermittent issue with the ignition.
    About half of the time, after driving, the key will not turn far enough back to lock to let me take it out of the ignition. This is an issue because now sometimes I have to leave the keys in the ignition and lock the doors!
    No matter what, if left for a bit (3-5 mins usually does it) it will unlock and turn backwards as it should. A tech friend of mine suggested it may be a heat thing. He said if you turn it really slow it should come out ok. Yeah, great, now 7/10 times it works, but is a big PITA!
    Anyone know how I go about fixing this?
    Thanks!
    Andrew
  2. #2 Re: Key intermittently won't come out of ignition
    GTX Level Member noreasonwhyy's Avatar
    Michigan
    quicker answers are provided when you use the search and find the answer. no need to wait for a response that's already existent, right?
    easiest fix is to pull the ignition solenoid. or you can override it by pushing the plunger on the solenoid by sticking something pencil-esque in the access hole on the underside of the column right by the ignition. you're probably looking at a bad ignition switch though.
  3. #3 Re: Key intermittently won't come out of ignition
    Akron Ohio
    Mine is doing the same thing it has somthing to do with the shiftlock.
  4. #4 Re: Key intermittently won't come out of ignition
    Stouffville, ON
    Quote Originally Posted by noreasonwhyy View Post
    Beings I've worked on GM stuff most my life and never heard of this, I didn't think it was THAT common. Regardless, Thanks for the reminder.
    Time to hit Rockauto... Thanks guys
  5. #5 Re: Key intermittently won't come out of ignition
    Jun 2010
    Saint Paul MN
    I had this issue on a 98 grand am and it was the shifter on the floor. the electric switch for the shifter was bad.
    97 gtp coupe XPZ,ported heads/LIM/TB,3.2 mps,42.5 inj,zzp headers/exhaust, doubleroller,etc..
  6. #6 Re: Key intermittently won't come out of ignition
    May 2008
    staten island,NY
    just remove the giant white ignition solenoid and problem solved. get up in the column with a long phillips screwdriver unscrew it and pull the plug
  7. #7 Re: Key intermittently won't come out of ignition
    Stouffville, ON
    Quote Originally Posted by QwikGT View Post
    Did that a few days ago based on whoever told me to do a search. Worked like a charm! Thanks !
  8. #8 Re: Key intermittently won't come out of ignition
    Donating Users Warbeaver's Avatar
    St. Louis
    father in law had problem with his regal. it was something in his shifter. had it fixed later.
    i was haviing this problem, but it was because i didnt have the shifter pushed all the way forward while in park. it would happen randomly. haven't had the problem since.
  1. I can't take my key out of the ignition!
    By Deezul_AwT in forum General Tech Discussion
    Last Post: 09-06-2010, 11:10 AM
  2. Replies: 1
    Last Post: 02-01-2010, 10:18 AM
  3. Low Oil Level Warning on Intermittently
    By Panzer4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-19-2009, 10:09 AM
  4. Rear windows intermittently work
    By 98GT3800 in forum General Tech Discussion
    Last Post: 11-20-2008, 07:33 PM
  5. Need More Help, Ignition
    By SyntheticShield in forum General Tech Discussion
    Last Post: 01-28-2008, 12:17 AM
