Thread: A/C Works, then Doesn't...?
Results 1 to 15 of 15
  1. #1 Re: A/C Works, then Doesn't...?
    GTP Level Member AjL227's Avatar
    IL
    Buy a set of R134 hot/cold side gauges, and study up on A/C systems for the DIY fix.
    '04 CompG "WS6"
    '00 2.5RS "GM6"
  2. #2 Re: A/C Works, then Doesn't...?
    swift current,sask.
    Quote Originally Posted by AjL227 View Post
    It can be but you need a vaccum pump and the disconect fittings for the automotive type fittings and all that other garbage. Refrigerant is about $35.00/lb so you won't be saving much in the long run.
  3. #3 Re: A/C Works, then Doesn't...?
    Charles City, IA
    Quote Originally Posted by whiney View Post
    Untill you start filling other peoples cars.
    SMGPFC Two Nipple General
  1. A/C problem. It works but it doesn't. Yes it's charged
    By TDCRacing in forum General Tech Discussion
    Last Post: 07-27-2010, 04:18 PM
  2. 99 GTP A/C works great, then stops, then works great again
    By stotzbotz in forum General Tech Discussion
    Last Post: 09-27-2009, 02:39 PM
  3. Gas gauge works then doesn't...?
    By 2001redfireGT in forum General Tech Discussion
    Last Post: 10-03-2008, 04:14 AM
  4. It Works!!!
    By 02BlueGT in forum PCM Tuning
    Last Post: 08-31-2008, 01:02 AM
