Thread: turning off headlights
Results 1 to 10 of 10
  1. #1 turning off headlights
    GT Level Member chickenfried's Avatar
    Feb 2010
    Gilman IA
    i want to make it so i have to maually turn on my lights with a switch. now they automatically turn on when its dark enough... could someone tell me with wire to cut or unplug?
  2. #2 Re: turning off headlights
    Charles City, IA
    Open the little cover on the side on the dash by the headlight switch and un plug the little black box. Works on some years, try a search you will find the answer for your year.
    SMGPFC Two Nipple General
  3. #3 Re: turning off headlights
    SE Level Member 00GTCoupe's Avatar
    Leeds, Maine
    Depending on year, you have to unplug the DRL diode and remove the auto headlight fuse in the glove box. There's a panel on the side of the dash, driver's side, that's where the DRL diode is. Some unplugged it, but I went up under with a 10mm socket & extension & unbolted it, then unplugged it.
    Mine is a 00 GT, BTW.
  4. #4 Re: turning off headlights
    GT Level Member BackInBlack's Avatar
    Vermont
    See my web site.
    The GPs are long gone...
  5. #5 Re: turning off headlights
    Feb 2010
    Gilman IA
    that website is great! thanks for the info guys
  6. #6 Re: turning off headlights
    SE Level Member hklvette's Avatar
    Jun 2010
    Christiansburg, VA
    on my 05 all i have to do is rotate the light switch backwards once and it disables automatic lights and DRLs.
    a newb's $.02
    '05 silver GTP, '98 Cherokee, '78 M880, '70 M35A2
    "Drag racing is for fast cars. Autocross is for fast drivers."
  7. #7 Re: turning off headlights
    SE Level Member Xhondaguy's Avatar
    May 2008
    chicagoland
    Well in mine if you put the parking brake on one click and shut off the car then start it back up the lights will stay off........until you take the parking brake off that is
  8. #8 Re: turning off headlights
    SE Level Member donnie98gtp's Avatar
    Nov 2009
    Plainfield, IL
    i just opened the fuse box in the glove compartment and removed the fuse labeled DRL, that did the job
    98 GTP: Spectre CAI, ZZPolys, SD Headers, 3.4", Dyno Tune...11 psi, 250fwhp
    94 Dodge Stealth RT/TT: K&N CAI, Eibach ProKit, KYBs, Y-Pipe, Downpipe, Polys, Stage3 Clutch, Fidanza Flywheel, DSM BOV, Boost Controller...14.5 psi, ~340awhp
  9. #9 Re: turning off headlights
    Feb 2010
    Gilman IA
    ^ that is wat worked to me
  10. #10 Re: turning off headlights
    Kansas
    Quote Originally Posted by donnie98gtp View Post
    X3.
    SOLD 1999 GT Silvermist TS
  1. headlights not turning on
    By nemesis in forum General Tech Discussion
    Last Post: 05-16-2016, 06:37 PM
  2. Turning on (nonworking) blower causes headlights to turn off
    By chilipepperpizza in forum General Tech Discussion
    Last Post: 05-03-2012, 11:14 AM
  3. Key not turning back all the way.
    By DJO in forum General Tech Discussion
    Last Post: 04-14-2009, 09:03 PM
  4. Turning a 01' SE into a GT
    By Dangerous313KidInAPrix in forum Visual/Body Modifications
    Last Post: 03-03-2009, 09:17 PM
  5. TCS not turning off
    By Keet04GTP in forum General Tech Discussion
    Last Post: 08-06-2008, 02:57 PM
