Thread: Center Console Trim Removal??
Results 1 to 7 of 7
  1. #1 Center Console Trim Removal??
    SE Level Member Risinnfallen's Avatar
    Lombard, IL
    Ok, well i did some searching and i really cant seem to figure it out i must be stupid... Anyways im painting the interior and i cant seem to figure out how to get the trim of off of the center console...any help would be great.. thanks!!
  2. #2 Re: Center Console Trim Removal??
    Saraland Alabama
    the top piece just pops off with very little pressure (cup holder and lid open) will need shifter in neutral at least to clear also
  3. #3 Re: Center Console Trim Removal??
    I had the same problem. Pull the visible bolts, and lift. Mine was stuck so hard I bent the clips... but thats what the bolts are for.
  4. #4 Re: Center Console Trim Removal??
    Lombard, IL
    Thanks for the help, i finished most of the painting and it looks great!!...now im going to work on my next project which is putting gauges in place of my display screen..
  5. #5 Re: Center Console Trim Removal??
    May 2008
    McHenry IL
    nice to hear i might go ahead and paint my interior plastics and stuff soon also.... i have a dk bronzemist metallic GTP wat color should i represnet inside?? White? Anyways send me a messege possibly any1 thanks for the input also what do you use to paint interior parts?
  6. #6 Re: Center Console Trim Removal??
    St. Louis Mo.
    I am going to be pulling my gauge cluster out this morning. I will snap a shot or two of the bolt/screws that need to be removed so that you can remove the center console. Once you remove those two screws it pretty much just wiggling it out of the center part of the console and around the shifter. It's actually pretty straight forward
    James Shafer
    St. Louis MO
  7. #7 Re: Center Console Trim Removal??
    SE Level Member kappa's Avatar
    Switzerland
    Old tread...but I must post.
    The top piece of the center console won't come up........
    Where are the screws? Must I remove the drinkholder completely?
    I want to remove it for installing gauges .......
    Thanx for your answers
  1. Making a bigger cubby hole in center console [*]
    By Toasty in forum How To Write-Ups/Tech Tips
    Last Post: 02-28-2009, 11:11 PM
  2. Removing center console
    By Deezul_AwT in forum Visual/Body Modifications
    Last Post: 05-21-2008, 08:22 AM
  3. Removeing 06 center console? Help!!
    By ABINOK in forum General Tech Discussion
    Last Post: 05-11-2008, 11:25 PM
