Thread: Intercooler clearance issue! Cut the hood or take out spacers?
Results 1 to 8 of 8
  1. #1 Intercooler clearance issue! Cut the hood or take out spacers?
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    I'm running a custom intercooler core. It is 1.75" tall. I was running a SS intercooler prior with no hood clearance issues. So the fact of the matter is I'm sitting 3/4" too tall now for my hood to close. So I have two options:
    1) Cut the hood, I currently have an SD Hood, but to be honest I don't even know if it will be enough clearance...........
    2) Take out my Vinnie Spacers and hope I don't get any vibrations from my SSC springs
    3) Get a new hood....... (ouch)
    Does anyone have a stock hood with a full sized intercooler?
    For all your 3800 needs:
  2. #2 Re: Intercooler clearance issue! Cut the hood or take out spacers?
    GT Level Member VictorSmalls's Avatar
    Dec 2008
    Tyrone, PA
    I would start with taking out the spacers and see where that gets ya. You need to figure it is something you can reinstall, where as the hole in your hood is not an easy fix.
    Retired
    Turbo'd
  3. #3 Re: Intercooler clearance issue! Cut the hood or take out spacers?
    Ohio
    u running a full or half set of spacers? if your running a full set take half out an try that
    00 GTP demodded and forsale
  4. #4 Re: Intercooler clearance issue! Cut the hood or take out spacers?
    Orange County, NY
    Right now I'm running a full set. I'm going to try and take half out next weekend and see where I stand.................urgggh
  5. #5 Re: Intercooler clearance issue! Cut the hood or take out spacers?
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    I have done a few full size IC installs on cars with the SD hood and GenV M90 and with stock mounts and 1/4" cradle spacers there was minor rubbing and ended up grinding part of the supercharger housing for clearnace. One of the cars is a good local friend that I have done a lot of work on over the years and we have played and played with it fighting the annoying vibration under heavy throttle, he also has lowering springs and the cradle spacers made it worse. Shortened dog bones werent much help even drilling holes to pull the engine up in a few different positions so the stockers went back on. You can put modeling clay on the supercharger in a few spots and then gently press down on the hood to leave impressions. I milled down the top of the supercharger housing a little where the plastic vacuum tree for the brake booster mounts on top as that was hitting the hood and on the front side of the supercharger where the nose bolts to the housing I had to grind a bit off there. I think the ZZP core is either 2 or 2.25" tall IIRC so being that you are 1.75" you should be better off. Also- the 97 boost bypass valve actuator vacuum line ports come out in a different location and can also hit the hood, not sure what year you have or at least for the actuator but check this also, hope this helps a little.
  6. #6 Re: Intercooler clearance issue! Cut the hood or take out spacers?
    Orange County, NY
    Thanks for the advise Trannyman, you are THE MAN. I can't even count how many times you've helped me out in the past!!!
    As far as some of your tips go:
    I have a 98,
    I'm going to try the clay this week and see where I'm hitting.
    And to give you an idea, the hood will close all the way down to the first latch, the blower actually hits the hood a little before the first latch engages, then the weight of the hood lets the hood hit the first latch. The second locking latch is impossible to get though, so I'm not really sure how much clearance I need for that extra amount of space. Maybe 1/2" ??????
    Either way, I'm going to hit the clay up, and take out half of my vinnie spacers. That will drop the engine down 3/8". We'll see what happens.
  7. #7 Re: Intercooler clearance issue! Cut the hood or take out spacers?
    Port Huron
    im running a 2.25" intercooled Gen V topswap and my SD sits on the belt wrap and vacuum tree all ready. I dont have spacers and I have stock dog bones I am getting a little Vibe with being lowered. should I save the money on painting the SD and stay stock hood. or is there an easy fix
  8. #8 Re: Intercooler clearance issue! Cut the hood or take out spacers?
    Cradle spacers
  1. Hood Clearance questions
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-16-2010, 04:10 PM
  2. 18s. no clearance and tire rub???
    By joshsGT in forum Tires & Wheels
    Last Post: 12-13-2009, 08:56 PM
  3. 2.25" intercooler core and ASCD SD hood? Clearance issues
    By copgtp in forum General Tech Discussion
    Last Post: 11-30-2009, 12:13 AM
  4. will ws6 hood fit over intercooler
    By 01gtpjk in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2009, 01:19 PM
  5. Would these have clearance?
    By Bogers99GTP in forum General Tech Discussion
    Last Post: 12-27-2008, 01:29 PM
