if its just a part throttle then it might just be your intake leaking.
How did the throttle body look? Mine was really dirty!!!! and I hit it with some cleaner and now its super quite. My only intentions were to fix the sticking throttle blade... which I did, but I also notice that when I turn my car off, it doesn't do that "one last breath, before sleep" thing anymore.
But I also used 3 cans of parts cleaner and 4 rolls of paper towel and about 150 q-tips to clean everything I put back on that wasn't getting replaced.
edit.... if u used a dorman intake... Just remembered that my new PCV holder wasn't holding it tight enough to the plenium, so I just used the original one, problem fixed!
I reused my UIM, because it was replaced in 2003 under warranty with the original owner. It looked great, so I just changed the gasket. I cleaned the TB last year and it was caked, but looked like new still last weekend.
In a rush to finish by the time it got dark last sunday, the last thing I installed was the rubber air intake tubing from the TB to the stock airbox. I popped it on the TB, but forgot to hook up and worm clamp the hose back onto the airbox side.
That explains my low mpg's, and that goes to show not to rush the work. At least it wasnt something major I forgot to do. Connected the hose to the airbox side and no more whistle.
Thanks for the help guys.
Good to hear that you got it figured out. You still got the stock airbox in there.....
