Thread: ignition locking key in
Results 1 to 4 of 4
  1. #1 ignition locking key in
    SE Level Member CompCam21's Avatar
    chicago
    So i have been having an issue with my key getting locked in the ignition. it seems to come and go randomly. what happens is i park my car, turn the key off, and try to get it out. however, it is locked in a position where the ignition is not on but it wount release. its almost like if u left the car in gear and tried to take the key out. i cannot even turn it backwards to the accesorry postion. nothing really seems to work to get it out. i try turning the car on then off, putting it in gear and taking it out, if i have the parking brake set i release it and change gears, turning the stearing wheel (which still moves freely because the key wount turn back to lock it). Ususally i end up sitting their turning the key fowards and backwards about a million times till it just decides to release for whatever reason. sometimes it takes a few turns sometimes i am literally their for minutes lookin like a fool haha. and then other days i have no issues at all. anyone have this problem before or know how to fix it?
  2. #2 Re: ignition locking key in
    GTX Level Member noreasonwhyy's Avatar
    Michigan
  3. #3 Re: ignition locking key in
    bg ky
    there is a small plug on the bottom of the steering column under the key that will pull out and you can put a pin in it and push up the weight it will let you take your key out if you are stuck in it away from home until you can replace the switch that is what i did and it worked fine.
  4. #4 Re: ignition locking key in
    GTX Level Member 98GTPCALGARY's Avatar
    Feb 2009
    Red Deer AB
    http://www.grandprixforums.net/f71/k...nder-7824.html
    this explains how to fix it. it took me all of 15 seconds to SEARCH it.
    Good luck. its an easy fix.
    98' GTP, 18's, BMR Adjustable Forward & Rear Lateral Arms, BMR Tubular Trailing Arms, Intense PCM, CAI, drilled rotors, 5% Tint all around
  1. SD Ram Air hood NOT LOCKING
    By Spartan GL in forum Visual/Body Modifications
    Last Post: 03-01-2010, 10:00 PM
  2. brakes locking up on me
    By Martin 04 in forum Brakes/Suspension/Chassis
    Last Post: 11-13-2008, 09:19 AM
  3. PE Not locking in at Zero?
    By Sabrewings in forum PCM Tuning
    Last Post: 08-12-2008, 06:54 PM
  4. Locking Lug nuts For GXP
    By GXPimpin in forum Tires & Wheels
    Last Post: 07-10-2008, 12:45 AM
  5. Door not locking
    By J_Man55 in forum General Tech Discussion
    Last Post: 06-30-2008, 01:09 PM
