Thread: Front end chattering on take off.
Results 1 to 6 of 6
atruebudfan Front end chattering on take... 06-02-2010, 05:17 PM
TheOtherNick Re: Front end chattering on... 06-02-2010, 06:06 PM
atruebudfan Re: Front end chattering on... 06-02-2010, 09:16 PM
CTKGP09 Re: Front end chattering on... 06-02-2010, 09:21 PM
atruebudfan Re: Front end chattering on... 06-02-2010, 10:00 PM
CTKGP09 Re: Front end chattering on... 06-02-2010, 10:05 PM
  1. #1 Front end chattering on take off.
    Punta Gorda, FL
    Ok so ever since I did the swap in my car there is a problem that has arisen. On hard take offs, even mild ones the whole front end chatters, only sometimes though. If you take off nice and slow it never seems to do it.
    The ideas that came to mind where one my tires, there very bald. So I thought they might be losing traction, but I peeled out before the swap and it didn't feel like this. The problem also happens under mild take offs so I'm not sure.
    Another idea was the driver half shaft might be bent. The car I got the swap out of hit a guardrail on the driver side, not super hard but the tie-rod was bent. The splines on the shaft looked good didn't think to see if it was bent. And if it is why only on mild to hard take offs and not all the time?
    These where the two I have been thinking about, thought I would post and see what you guys could come up with. Thanks for any help.
    2000 Pontiac Grand Prix GT (98' L67 engine/trans swap)
  2. #2 Re: Front end chattering on take off.
    Charles City, IA
    Did Check everything and make sure it is tight. Could be an axle also.
    SMGPFC Two Nipple General
  3. #3 Re: Front end chattering on take off.
    Punta Gorda, FL
    Yea everything was torqued down that needed to be, was thinking of going over some things again though. If something is loose it should do the same thing on hard braking, and nothing happens then though.
  4. #4 Re: Front end chattering on take off.
    Willoughby, Ohio
    check all mounts again, axels, and codes?
  5. #5 Re: Front end chattering on take off.
    Punta Gorda, FL
    It does kinda feel like a TC locked up but there are 0 codes. I am going to checkout the mounts and the axle end nuts.
  6. #6 Re: Front end chattering on take off.
    Willoughby, Ohio
    lug nuts too for the hell of it
  1. where to buy a front lip for a GXP?
    By highonpsi in forum 5.3L V8 (LS4)
    Last Post: 08-08-2010, 12:12 AM
  2. Front end
    By Independentvice in forum Brakes/Suspension/Chassis
    Last Post: 10-28-2009, 01:11 AM
  3. Hum from the front end.
    By c002529 in forum Brakes/Suspension/Chassis
    Last Post: 10-18-2009, 07:46 PM
  4. Who's that in front of my GXP?
    By Injun #4 in forum Off Topic Discussion
    Last Post: 10-01-2008, 07:06 PM
