Thread: Cleaning coolant overflow ......
Results 1 to 13 of 13
  1. #1 Cleaning coolant overflow ......
    Brewcity, WI
    I am doing car work and was wondering how to get this dexcool residue off of the insides of the overflow tank. I've run plenty of water through it already. And shook the crap out of it, but this stuff on the sides wont budge!!
    Can I just spray some brake parts cleaner in there?
    tank
    http://i162.photobucket.com/albums/t...0/IMG_0174.jpg
    rad cap, yummy!!
    http://i162.photobucket.com/albums/t...0/IMG_0173.jpg
    Self-denied SMGPFC member #1
    SEARCH works!
  2. #2 Re: Cleaning coolant overflow ......
    buy a new one dude. i tried everything to clean mine. its literally impossible without cutting it open, scrubbing it with a wire brush, then putting it back together. you wont clean it.
  3. #3 Re: Cleaning coolant overflow ......
    Brewcity, WI
    where would I get one of these..... without mail order.
    napa, autozone, advance auto parts, oriely's... nothing, not even rockauto!
    PFYC does http://www.pfyc.com/pc/GP3009/IM/.html
    SEARCH works!
  4. #4 Re: Cleaning coolant overflow ......
    Apr 2009
    stockton ca
    tried to do mine used the coolant flush crap steam cleaner and solvent nothing worked buy new
  5. #5 Re: Cleaning coolant overflow ......
    Apr 2009
    stockton ca
    i was gonna say rock auto lol
    stealership probably autozone i dont know though
  6. #6 Re: Cleaning coolant overflow ......
    GT Level Member djrepoman's Avatar
    columbus ohio (polaris)
    Intense has them if you decide to mail order
    2000 GT ,E85 powered, and still slow
    98 GTP Stock
  7. #7 Re: Cleaning coolant overflow ......
    Joliet, IL
    zzp has em as well.
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  8. #8 Re: Cleaning coolant overflow ......
    Brewcity, WI
    good thing that I wait until now to do this... going to try the stealership tomorrow. Just don't want to mix my new coolant with that crap in there. Figure drain, water, drain, water, drain, cleaner, drain, water, drain, coolant..... that should do it.
    Didn't even cross my mind when I ordered from ZZP last week.....F it I'm getting a Hardee's thickburger!!
    SEARCH works!
  9. #9 Re: Cleaning coolant overflow ......
    Joliet, IL
    Quote Originally Posted by Pepino View Post
    i got lucky mine has minimal build up in the tank when i switched to green.
    00 Silvermist GTP
  10. #10 Re: Cleaning coolant overflow ......
    May 2008
    Coolant Reservoir costs about $50 at the stealership.
    Would the powerwash at a car wash remove the residue?
    Soda Blasting?
    CLR Remover?
  11. #11 Re: Cleaning coolant overflow ......
    GTP Level Member
    Pittsburgh
    ok since noone has posted,
    take a old rag, soak it with brake clean, stuff the rag in the overflow, and shake the crap out if it. then the corners, a long screwdriver or whatever will clear up the rest.
    i have done this on many cars to get the bottle looking new again
    2003 SSEi,
  12. #12 Re: Cleaning coolant overflow ......
    GTP Level Member lambokit's Avatar
    Apr 2009
    Radford, Virginia
    ^X2. I just did mine this past weekend. Stuff a rag in it, spray the sh*t out of it with brake cleaner and use a long screwdriver and then a coat hanger to get around the center piece. Then rinse with water. Works like a charm...
    Lambokit to be built!!!!!
  13. #13 Re: Cleaning coolant overflow ......
    Jul 2008
    nj
    I only know of 1 way to clean the inside of that container and it will make it look like new. Go in your kitchen and get some coffee....yes coffee. Put in enough coffee grinds for a pot of coffee and enough water for a cup of coffee. Then shake it.....well make sure you cover the opening first. Trust me...it works
    FOR SALE
    2003 GTP, L36 swap, TOGs extremes, ZZP stage 3 heads, SSIC, ZZP Ported Blower, 3.0/3.2 pulley, XP hot cam w/ 105#, 42.5# injectors, N* w/ 85mm MAF, Meziere Water Pump.
  1. coolant overflow tank GM Part number anyone?
    By Liquifire in forum General Tech Discussion
    Last Post: 08-30-2012, 06:48 PM
  2. Radiator Overflow Cap
    By kingbrentdwyer in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-13-2009, 06:22 AM
