Thread: fuel line nut rusted to fuel line!!
Results 1 to 20 of 33
  1. #1 Re: fuel line nut rusted to fuel line!!
    SE Level Member ParanoidVengeance's Avatar
    Jun 2010
    Canton
    The fuel line won't be long enough once you cut it. Since you have rust on the line and will have to cut back past it to get to good tubing. You are gonna be way short. Not to mention. You will have to buy a fitting. And when I said put a flare on tubing, just ment a little bend outward to keep it on the hose.
    If you do go with a compression fitting. It will be more solid.
    2004 Monte Carlo Supercharged transplant
    Comp Cams 1.9 rockers
    Headers w/3 inch exhaust no cat
    Gutted Air Box,ZZP 1.0 PCM Dyno Tuned
  2. #2 Re: fuel line nut rusted to fuel line!!
    GT Level Member sic6's Avatar
    san marcos, tx
    I would just cut the rusted line off, get a new section of tubing so that when you cut the damaged section out you will have enough length to reach the fuel filter.Install the new piece of line with the correct fitting for the fuel filter and you can use a compression fitting to connect the lines but i would just flare them and install a union fitting to join the two ends.Not that hard to do, just takes more time to do and is a better long term solution than installing rubber fuel line with hose clamps.
  1. Fuel line to fuel filter cracked need help asap
    By Jays98GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-30-2010, 04:20 PM
  2. Fuel line disconnet
    By indyal in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-28-2009, 08:22 AM
  3. Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    By Iron Indian in forum How To Write-Ups/Tech Tips
    Last Post: 01-17-2009, 07:53 PM
  4. fuel line identification help
    By sra_chipmunk in forum Off Topic Discussion
    Last Post: 07-06-2008, 12:30 PM
  5. AN Fuel Line Setup
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-22-2008, 06:26 AM
