Thread: Are my cluthes toast? FU firestone!!!
Results 1 to 8 of 8
  1. #1 Re: Are my cluthes toast? FU firestone!!!
    Brewcity, WI
    This is the only other pan drop I did besides a Dodge....which had major tranny issues to begin with. Just thought this looked way worse then the one pictured in links that I've found. But this is good to know..... Thanks
    Also noticed that it looks like something is rubbing the pan. Which I'm thinking is the filter wasn't seated all the way... nothing a rubber mallet didn't fix.
    http://i162.photobucket.com/albums/t...0/IMG_0142.jpg
    Self-denied SMGPFC member #1
    SEARCH works!
  2. #2 Re: Are my cluthes toast? FU firestone!!!
    is that on the inside or outside?
    As for the dust and stuff, every single tranny is going to wear some, so dust is normal, but its when you start seeing bigger metal shaving and chunks that when you have a problem.
  3. #3 Re: Are my cluthes toast? FU firestone!!!
    Brewcity, WI
    Thats cool, thanks. Didn't see any fillings/chunks or anything in the pan, but the magnet had stuff just like my magnetic oil plug does. Kinda like little slivers... and I mean little. Had to look at them in direct sunlight to see them.
    The mark is on the inside.
    So you guys are saying that they probably did the service? Have done alot of towing around a 700 lb. waverunner and moved twice since then.
    SEARCH works!
  1. The legendary 4th clutch shaft toast
    By GTPJOE90 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-13-2011, 10:41 AM
  2. 3rd gear toast
    By izup69 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-15-2009, 07:03 AM
  3. Last of a dying breed! A Toast.
    By Toofastgs in forum Off Topic Discussion
    Last Post: 05-03-2009, 07:17 PM
