Thread: wtf cam?
Results 1 to 11 of 11
  1. #1 wtf cam?
    GT Level Member kuntzie's Avatar
    Feb 2010
    Kitchener, Ontario, Canada
    so what the helck kind of cam is this.. i could not find anything to close to these numbers on zzp
    specs-------- Int Exh
    adv dur. 274 276
    dur @ .050 224 224
    valve lift .574 .566
    Lobe Sep: 114.0
    02 Grand Prix GT Intercooled turbo 5-speed 718whp 618wtq @ 21psi 7575 billet, spool valve, custom manifolds, 4" downpipe, 16way adjustable coilovers, 18x9.5 with 275's all around, gxp interior, gxp brakes
    tilton triple disc, custom aluminum flywheel, tilton slave and master, an awful lot more
  2. #2 Re: wtf cam?
    Charles City, IA
    Its a bigin.
    SMGPFC Two Nipple General
  3. #3 Re: wtf cam?
    .....where is that cam being sold?!
    THAT'S THE CAM I HAD!! NO ONE HAS RUN THAT THING YET!!! NO WAY!!
    it's based off the trasher race cam (TEP) with some more intake lift. it will be a mean, MEAN cam. it will also go absolutely awesome with a turbo setup...that you have...
  4. #4 Re: wtf cam?
    Charles City, IA
    The duration is a lot longer than the tep also.
  5. #5 Re: wtf cam?
    yes...but that's my cam. there is no doubt about it. it's a one off. is someone selling that on clubgp? is dustin selling that?
  6. #6 Re: wtf cam?
    Feb 2010
    its in canada, it comes with 130# springs
    i really really dont want to take the heads off my car yet, can this be ran with stock heads with the 130s? (rollermaster aswell)
    wat about pushrods and such
    ps how about idle
    and yes i know heads would be great, but im waiting for winter for that,
  7. #7 Re: wtf cam?
    it CAN run it with 130# springs and modded retainers, but its not how it should be ran. stock pushrods will be fine with this.
    look at this ad, you need their 'stock heads install kit':
    http://www.3800performance.com/Merch...oduct_Count=12
  8. #8 Re: wtf cam?
    Feb 2010
    what is suggested then?
  9. #9 Re: wtf cam?
    yes, the indicated overall lift is on the stock 1.6:1 rockers.
    if it were ME doing this, i would buy a set of heads on the side and get them ported, polished, and the guides milled down to run the cam properly. this cam is an awesome one for you to stumble upon for your setup and it'd be a waste for you to not use it to its' full potential.
    however, if you get ahold of 3800 performance you can buy their 'TEP cam install kit' which would give you everything you need to run it.
  10. #10 Re: wtf cam?
    Feb 2010
    im going to be getting heads done this winter, as i said before. afaik the heads are good for 600 lift with the 130 springs.
  11. #11 Re: wtf cam?
    good for .600" lift with the 130# springs and the right retainers and seals.
cam, wtf
