Thread: Never heard of a misfire like this
Results 1 to 1 of 1
  1. #1 Never heard of a misfire like this
    SE Level Member TheGreatSamG's Avatar
    Oct 2008
    chicago
    I have been upgrading my 98 gtp for the past month and doing basic maintenance.
    valve cover gaskets
    fuel injectors because of cylinder injector randomly sticking
    zzp downpipe with magnaflow cat
    zzp pcm 1.0
    crankshaft position sensor because randomly my rpms would drop
    i had to take out the voltage booster because it was making my car misfire. mechanic says that there was no voltage going to injector 5. but after i took out the voltage booster it stopped misfiring at idol
    and within the past couple of weeks its been misfiring alot. runs smooth in idol. but as i floor it - misfires. after 2000rpms - misfires.
    if i put it in neutral and floor the pedal it wont misfire. just seems as if it only does it in gear or in park. check engine light came on the codes that popped up were P0205, P03513, P1652.
    and i put in autolite 104s with a .055 gap.
  1. Ever heard of this...
    By wrfdff4 in forum Tires & Wheels
    Last Post: 01-20-2010, 08:53 PM
  2. Anyone heard of the ZZP SS M90 KIT?
    By Nickell in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-07-2009, 03:09 AM
  3. Heard of an easy mod
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-03-2008, 01:06 PM
  4. been not heard from for a while WHY you ask ?
    By GAGT+GP-OWNER in forum Introductions/Noob Questions
    Last Post: 08-24-2008, 08:55 PM
  5. anyone heard of an HID kit from www.vvme.com?
    By Zainoman in forum Off Topic Discussion
    Last Post: 05-29-2008, 12:04 AM
