Thread: if anyone needs intake ideas...
Page 1 of 5 123 ... LastLast
Results 1 to 20 of 97
  1. #1 if anyone needs intake ideas...
    Its not that small is it? DaytonaGTP's Avatar
    Nov 2009
    Michigantown, IN
    this what i did a couple months ago... all i did was cut the factory pipe just before the iat and clamped the filter on... 15 minutes and youre done...
    2000 Daytona GTP(aka the slow fwd GTO)
  2. #2 Re: if anyone needs intake ideas...
    Donating Users Warbeaver's Avatar
    St. Louis
    meh, get some pvc pipe, paint it, and stick that filter in or near the fenderwell. your intake temps are gonna be hot with an intake like that. my intakes have always been at or 10*+ ambient temps at most
  3. #3 Re: if anyone needs intake ideas...
    Fenderwells are for girls and people who like water in the engine.
    Mod it and then go open cone.
  4. #4 Re: if anyone needs intake ideas...
    Quote Originally Posted by Warbeaver View Post
    your point?
  5. #5 Re: if anyone needs intake ideas...
    GTP Level Member lambokit's Avatar
    Apr 2009
    Radford, Virginia
    A mist of water in the intake every now and than is not always a bad thing... I.E. Jeep water droplet injection kit to keep the combustion chamber steam cleaned and running good.
    Lambokit to be built!!!!!
  6. #6 Re: if anyone needs intake ideas...
  7. #7 Re: if anyone needs intake ideas...
    St. Louis
    lol if you're not gonna suck up water with an intake at the top of your fenderwell. I had one with no problems. Water cannot pass through that filter unless you completely submerge the thing in water. Water droplets cannot pass through the material and the oil coating it
  8. #8 Re: if anyone needs intake ideas...
    water droplets will get through, i've never sumerged my FWI and you can see the water marks inside the intake tube.
    Chopped it off now I have a 4" short ram.
  9. #9 Re: if anyone needs intake ideas...
    thats why anyone that runs a REAL FWI is dumb for not running a smaller inline filter in the middle just in case the bottom end gets straight water....dduuhhhh.
  10. #10 Re: if anyone needs intake ideas...
    '02 GTP oneil.GTP's Avatar
    Oct 2008
    Peoria, IL
    kinda along the same lines.. but would heat wrap around the intake tubing help keep temps low or just skip that step and do a heat shield?
    or both?
  11. #11 Re: if anyone needs intake ideas...
  12. #12 Re: if anyone needs intake ideas...
    Oct 2008
    Peoria, IL
    so it wouldnt help?
    i got plenty of time. and i have everything, so cost is nothing.
  13. #13 Re: if anyone needs intake ideas...
    Banned
    Mansfield, Ohio
    Fender well intakes and true cold air intakes keep the temperatures down compared to an open cone. I believe w-body store or zzp, someone tested the different in intake air temps and open cones run about 70 degrees hotter than something that's sealed off away from the heat. Add that to your supercharger heat and you're creating knock, maybe to the point where it's not helping at all as far as performance but just to your ear!
  14. #14 Re: if anyone needs intake ideas...
    Quote Originally Posted by cleangtp View Post
    your post count reflects your knowledge on the subject.
  15. #15 Re: if anyone needs intake ideas...
    May 2008
    staten island,NY
    get rid of the airbox for a turbo, problem solved
  16. #16 Re: if anyone needs intake ideas...
    post count does not always do so, but in this case i agree.
  17. #17 Re: if anyone needs intake ideas...
    Topeka, KS
    Meh i'm glad i went Open Cone. My Filter stay's cleaner without nasty **** all over it. And besides the only time i need that colder ambient temp is when i race and i haven't went once yet this year. I'll take my Fuel Mileage .
  18. #18 Re: if anyone needs intake ideas...
    Willoughby, Ohio
    sooo many short ram vs open cone vs fenderwell threads! i thought we all agreed? buy a price of 4'' diameter pipeing and put a filter on then upon heavy modding go open cone, DUH
  19. #19 Re: if anyone needs intake ideas...
    Joliet, IL
    SRI/OC+LQ4=instant refresh rates. FTW. end thread.
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  20. #20 Re: if anyone needs intake ideas...
    Banned
    Mansfield, Ohio
    Been buying/making/fabricating intakes for probably longer than you've driven a car son. I guarantee if you put an aeroforce on a factory intake setup it has less knock than an open cone. I'll supply video evidence if you need it! You're inlet temps for an open cone roughly 144 degrees. Close it off and cut it in half! 144 degree intake air temps, nah I'll pass on that. Not to mention if an open cone filter setup was so great makes you wonder why they didn't put it on for a factory setup, let me help you it creates more knock which in turn takes away reliablity of your vehicle.
    Of course this is coming from the same guy that gives me **** everytime I post here and we already know you have attitude/personality problems. Why I don't post here often so I don't have to hear your stupid mouth.
  1. any mod ideas?
    By EJRJR91 in forum Visual/Body Modifications
    Last Post: 03-28-2010, 01:35 PM
  2. Any mod ideas?
    By EJRJR91 in forum Introductions/Noob Questions
    Last Post: 03-23-2010, 09:56 PM
  3. ideas
    By Will5600 in forum General Tech Discussion
    Last Post: 03-18-2010, 07:27 AM
  4. Coolant Loss, intake Gasket or Intake Itself???
    By WoR in forum General Tech Discussion
    Last Post: 04-29-2009, 04:02 PM
  5. Looking for some Mod ideas for new GP GT
    By massivesystem in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-11-2008, 06:01 PM
