Thread: Question about air intake installation
Results 1 to 8 of 8
  1. #1 Question about air intake installation
    SE Level Member GothTP's Avatar
    Hollywood, FL
    I have a 97 GTP. Today I got my air intake. When I removed the stock air filter I noticed a metal box with may wires comingout that said Delco Electronics, inside the black plastic enclosure where the stock air filter is. In order to install the new intake I had to remove the plastic enclorure so the metal box is now in the open.
    My questions are: What is that box and where can I put it to keep it safe?
    Here is an actual pic of my car with the new filter and the Delco box in the right.
    http://www.mysticequineart.com/dsc05801.jpg
    Thanks a lot
  2. #2 Re: Question about air intake installation
    MA
    that box is your pcm (cars computer)
    alot of guys just leave it laying there and say its fine, but i wouldnt do this, in my mind its to crucial of a component to be lef laying around.
    some guys have used zip ties to hold it in place. I believe i heard that chevy s10s have a tray for it that is a perfect match for our cars, you could probably find one at a junkyard for cheap.
    SMGPFC Member #9
  3. #3 Re: Question about air intake installation
  4. #4 Re: Question about air intake installation
    SE Level Member RideMr2's Avatar
    Memphis
    You can leave the PCM where you have it, but it would be much better if you could get it bolted in there someway so it doesn't bounce around.
  5. #5 Re: Question about air intake installation
    MA
    that intake is tiny.
    yeah you should think about a bigger filter
    SMGPFC Member #9
  6. #6 Re: Question about air intake installation
    the filter is good, im talking about the tubing. you want 4" for sure.
  7. #7 Re: Question about air intake installation
    MA
    well im used to my 9 inch, still think yours could be bigger OP
    SMGPFC Member #9
  8. #8 Re: Question about air intake installation
    Hollywood, FL
    Thank you guys, for all your help. Glad I can count with you all.
  1. Intake question....
    By JESSEGOTTA GP GT in forum Shops and Community Heroes
    Last Post: 12-27-2011, 07:06 PM
  2. FWI(fender well intake) question. Exhaust(cat) question.
    By DJspinner in forum General Tech Discussion
    Last Post: 01-23-2010, 01:47 AM
  3. Water Pump Installation Question
    By Lawngoose in forum General Tech Discussion
    Last Post: 12-07-2009, 09:52 PM
  4. deck installation question??
    By reallyfast1 in forum Audio, Security & Visual Electronics
    Last Post: 07-04-2009, 07:40 AM
  5. question about my k&n intake
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-05-2008, 10:48 PM
