Thread: zzp pcm
Results 1 to 18 of 18
  1. #1 zzp pcm
    Donating Users zildjian102's Avatar
    Wilkes Barre, PA
    People are telling me this pcm isnt very good for the gtp? How so? I've been looking at the 3800 performance website.. the pcm is the same price and does the same thing so is there really a difference?
    2002 Grand Prix GT- top swap soon
    1997 Pontiac Grand Prix GTP-project/parts
    3.4 pulley, intense tune, SD headers, intake, 180 tstat, al104's
  2. #2 Re: zzp pcm
    Portland Oregon
    People say this on assumption. Dhp is a good PCM, zzp is a good PCM. You will always benefit from a custom tune. I runn a zzp an see afr's of around 10.9-11.4 at wot depending on the weather and people say their pcm's run lean lol.
  3. #3 Re: zzp pcm
    Wilkes Barre, PA
    Whats the ideal afr for our cars to be running at..? i know that the old engine was blown because he had no reprogrammed pcm and the engine was running too lean cause he had an intake and a smaller pulley.. thats why he put the new pcm in when he got the new engine
  4. #4 Re: zzp pcm
    Apr 2009
    stockton ca
    my intense pcm runs around that maybe a little more on the rich side
    i think it also comes to reason that mistakes in tunes are to be expected no matter what tune you run and also that some engines just die no fault of the pcm
  5. #5 Re: zzp pcm
    '02 GTP oneil.GTP's Avatar
    Oct 2008
    Peoria, IL
    no problems with my zzp pcm..
  6. #6 Re: zzp pcm
    GT Level Member mvp2765's Avatar
    Chicago
    my old engine ran too rich with a zzp tune.. i kept blowing plugs..i had a lot of other mods tho so that could have been an issue also
    00 Black GTP Coupe - SOLD
    04 Black 350Z touring -currently modding
  7. #7 Re: zzp pcm
    SexyStudmuffin copperpacecar's Avatar
    Feb 2010
    somewhere cold
    ive heard time and time again that zzp cant tune and i disagree. i tune with hptuners and yes they seem to run you rich but i agree that they should. they cant run your car to the limit as they cant see your car so they put in a margin of safety (at the price of running rich and soft on timing) to compinsate for all the different factors your car can pick up. what if they pushed your tune to the limit and u have a bad fuel filter...by by motor. i have viewed their (canned) tunes and believe they r very compitent at what they do. their tune will run circles around your stock tune and add power/life to your car if u have mods but havent gotten to the point where your ready to tune yourself yet.
  8. #8 Re: zzp pcm
    Donating Users Ibwrong's Avatar
    Oklahoma City
    Quote Originally Posted by zildjian102 View Post
    Thats why he messed his engine up....
    2000 GTP - Project
    2000 Mustang GT
    2006 Charger
  9. #9 Re: zzp pcm
    Wilkes Barre, PA
    Well then it sounds like i have nothing to worry about with the pcm.. the original owner said he never scanned for kr but I have all the supporting mods for the smaller pulley.. so should i really be worried about it?
  10. #10 Re: zzp pcm
    Oklahoma City
    Just get a scanner and keep an eye on everything.. If you have the supporting mods you still need to scan to make sure your going to lose the front bank of pistons.... On a side note, I would consider headers before you drop down to a 3.4...
    2000 GTP - Project
    2000 Mustang GT
    2006 Charger
  11. #11 Re: zzp pcm
    Wilkes Barre, PA
    I have no clue what size pulley is on it now.. all i know is that at WOT i get 12 psi of boost..
  12. #12 Re: zzp pcm
    Oklahoma City
    12psi...? Thats closer to a range of 3.3 -3.0 isnt it? Someone correct me if Im wrong...
    2000 GTP - Project
    2000 Mustang GT
    2006 Charger
  13. #13 Re: zzp pcm
    Wilkes Barre, PA
    The guy said he only went one size smaller than stock but that cant be if I'm running 12 psi right..? and 12psi is what the aftermarket boost gauge goes up to and I'm sure the gauge dosent lie lol
  14. #14 Re: zzp pcm
    GT Level Member GeosGP's Avatar
    Fenton, MI
    12.5 AFR or numerically lower is considered optimal for power, but in the mid-11's is safer. Sounds like the previous owner got greedy and overdid it without tuning it. That's a shame...
    You should get scanner on there ASAP. Look into an Aeroforce.
    2004 Grand Prix GTP Comp-G
    Stock, featuring more KR than you can shake a stick at
  15. #15 Re: zzp pcm
    Apr 2009
    stockton ca
    Im running a 3.4 pulley and only have 10 psi max boost
    I would definatly scan the car my guess is you have some kr at wot
  16. #16 Re: zzp pcm
    GTX Level Member Juanmiguel's Avatar
    Mexico
    Does your car have a 3" DP and/or PLOG? 12 psi is way high and I would do those if not headers before anything else.
  17. #17 Re: zzp pcm
    Get headers first. Espiecally with a GenV car your knocking with 12psi for sure.
    It is probably a 3.4"...which is headers/rockers, or an IC, or cam territory. Just an FYI. Click the link in my sig for more info. IMO, too many people have had issues with Intense, or ZZP PCM's in the past for that matter. Which is why I say get DHP's. Buy from 3800 Performance...best mail order tune out there...tried and true for years.
  18. #18 Re: zzp pcm
    Wilkes Barre, PA
    is there any way where i could find out the pulley size? I put measuring tape next to it and it looked like it was around 3.5 or 3.6 but i couldnt tell, there was barely any room
pcm, zzp
