Thread: security light
Results 1 to 14 of 14
  1. #1 security light
    SE Level Member Myprixxx's Avatar
    Apr 2008
    Decatur, IL
    so a buddy of mine bought a gtp recently, and it came with an autotap code scanner.. unfortunatley the software with it was made for windows 95 or something crazy like that, so he went online and downloaded a few newer versions and we tried to scan my car.. laptop says it cant connect we tried probably three or four times, then the car would start for a few seconds then die.. so i tried a security relearn.. this got the car running but security light blinks.. occasionally will go off but then right back on.. so last night i tried doing a security relearn again to get the light to shut off.. this time the car wont start at all.. so i did the other security relearn (out of the 2 on zzp since they were all i found) and the light went off, pulled the car in the garage and when we went to pull it out.. surprise, security light is back.. what could i have done and what the hell can i do to shut this light off?? it also feels like if i try to go WOT the car wont really let itself, and that wasnt a problem before this light
    i knew this guy wasn't b/sing.
    michigan people have better stuff to do, like finding jobs or avoiding robbery.
    quoted from noreasonwhyy
    GenV, Full sized I/C, HAI, 3.0 MPS, N* TB
  2. #2 Re: security light
    Outer Space
    Quote Originally Posted by Myprixxx View Post
    Are you using a passkey? ... has PK stamped on the key... or a valet key (no chip) inside.
    02 GTP 13.6 @ 100mph - SOLD
  3. #3 Re: security light
    Apr 2008
    Decatur, IL
    as far as i know it is a passkey, it is the black key that i have always used.. (my valet key has a silver "valet" cover.. it saYS PK3 then M underneath that on the key im using.. the only one ive ever used in the car minus a time or two when i was in a huge rush
  4. #4 Re: security light
    Outer Space
    black key = prolly passkey.
    Security light - HP Tuners Bulletin Board
    I don't know off the top of my head if the BCM is involved.... long day (Header install)
  5. #5 Re: security light
    Apr 2008
    Decatur, IL
    i will read up on this and post back.. thanks a ton, ive never really posted here much, used cgp a lot more, but i havent gotten a single thing back from them yet.. thanks again and ill let you know how it goes.
  6. #6 Re: security light
    Outer Space
    ***fingers crossed***
    Let us know how it goes regardless.
  7. #7 Re: security light
    Apr 2008
    Decatur, IL
    update: it says something about a bad pass lock sensor.. how would i know if this was bad? also, what would i need to replace if i didnt want to solder something in there? the BCM or the sensor and where is the sensor located?
  8. #8 Re: security light
    Apr 2008
    Decatur, IL
    bump before work.. throw out any ideas you can think of on what it could be or how the hell i could fix it..
  9. #9 Re: security light
    Apr 2008
    Decatur, IL
    random bump
  10. #10 Re: security light
    Apr 2008
    Decatur, IL
    nobody else?
  11. #11 Re: security light
    Charles City, IA
    A lot of the cars have a problem with the harness for the pass key system that is attached to the steering column. Mine randomly started having problems with it too, I have not bought the updated harness yet Every now and then I just have to do a relearn. The harness is not cheap IIRC it was like $80-120 our cost.
    SMGPFC Two Nipple General
  12. #12 Re: security light
    Apr 2008
    Decatur, IL
    what would i call the updated harness? i need to find somewhere i could purchase it
  13. #13 Re: security light
    Charles City, IA
    Antitheft System - Engine Stalling/Multiple DTC's Set
    File In Section: 08 - Body and Accessories
    Bulletin No.: 02-08-56-002
    Date: November, 2002
    TECHNICAL
    Subject:
    Engine Stalls, Security Lamp Illuminated, DTCS P1626, P1629, B2955, B2960, B3022, B3023, B3024, B3025 Set (Replace Theft Deterrent Control Module)
    Models:
    2000-2003 Pontiac Grand Prix Built Prior to VIN Breakpoint 3F115058
    Condition
    Some customers may comment that the vehicle starts then stalls and the security lamp is illuminated. These symptoms may be intermittent and after several start attempts, the vehicle may stay running. Upon investigation, the technician may find DTCs P1626, P1629, B2955, B2960, B3022, B3023, B3024, B3025 set and the PASS-KEY III(R) fuse blown.
    Cause
    This condition may be caused by either a chafed wire in the theft deterrent module wiring harness or an electrical interference within the theft deterrent module not allowing the fuel enable signal to be detected.
    Correction
    Replace the theft deterrent module with P/N 10335045 and reroute the module wiring harness to a new location using the procedure listed below.
    1. Replace the theft deterrent module. Refer to the Theft Deterrent Control Module Replacement procedure in the Theft Deterrent sub-section of the Service Manual.
    2. Reroute the module harness (1) on the outside of the steering column channel and tie strap the lower portion to the larger ignition bundle.
    3. Replace the tie strap removed from the tilt head during disassembly. Secure the new strap in the hole in the tilt mechanism and around the module wires and the ignition and SIR wires, but below the tie strap located on the SIR wires.
    Parts Information
    Parts are available 11/11/02 from GMSPO.
    Warranty Information
    For vehicles repaired under warranty, use the table.
    Disclaimer
  14. #14 Re: security light
    Apr 2008
    Decatur, IL
    thank you 01GTP!! well see how that works
  1. Security Light
    By SMOKIN GTP in forum General Tech Discussion
    Last Post: 05-10-2010, 02:38 PM
  2. Flashing security light??
    By 91z in forum General Tech Discussion
    Last Post: 03-03-2010, 03:22 PM
  3. Security light blinks
    By Falco in forum General Tech Discussion
    Last Post: 12-01-2009, 10:55 AM
  4. Security Light Flashing
    By 01GPSE in forum Audio, Security & Visual Electronics
    Last Post: 01-06-2009, 11:58 AM
  5. Security light comes on at random
    By Andrew_99GTP in forum Off Topic Discussion
    Last Post: 05-19-2008, 09:44 PM
